We are streamlining our deployment and maintenance scripts for our openbalena instance and I noticed there is a variable called OPENBALENA_RESINOS_REGISTRY_CODE in the default build scripts that is generated but then seems to be unused. Could someone at balena confirm if this is the case?
Hi, I’m not aware of the purpose the variable may have served in the past (checked with a more experienced colleague and he is not aware either). But we don’t see any references to that variable through the balena-io org, so it indeed appears to be unused.
@myarmolinsky thanks for chasing this down!
No problem, let us know if you have any other questions ![]()
