xserver-web-vnc X11 MIT Shared Memory Attach failed:
xserver-web-vnc Is your DISPLAY=:0 on a remote machine?
xserver-web-vnc Suggestion, use: x11vnc -display :0 ... for local display :0
xserver-web-vnc
xserver-web-vnc caught X11 error:
xserver-web-vnc 21/08/2021 02:46:26 deleted 60 tile_row polling images.
xserver-web-vnc X Error of failed request: BadAccess (attempt to access private resource denied)
xserver-web-vnc Major opcode of failed request: 130 (MIT-SHM)
xserver-web-vnc Minor opcode of failed request: 1 (X_ShmAttach)
xserver-web-vnc Serial number of failed request: 56
This project is using the exact type of xerver implementation I am so if we can fix this one, then we can fix mine. I am hesitating to post mine right now because it is still in dev and a bit more messy and complicate. I will happily post more information as needed, but just wanted to get the ball rolling in case maybe someone knows the obvious reason why this does not work. Appreciate nay thoughts.
@mopus. Yes that would indeed be helpful information, I am sure. Ha. I am using an RPi 4B with 5.1.20 installed.
I have “fixed” this. I had to install vnc in the xserver block (Dockerfile) itself then running it from entry.sh. Really do not like this solution, as running vnc in its own block is far more elegant, but can’t find a solution to the problem above and been at it for hoooouuurs.
