I have in my dockerfile to pip install ffmpeg but when I go into my terminal and try to locate the version, I get no result. Anyone have an idea on how to install ffmpeg, that would be greatly appreciated. Thanks
Can you link exactly which PyPi ffmpeg Python package you are trying to install through your dockerfile? I was able to find an exact match which was ffmpeg · PyPI and several others
Also, please do provide the exact error message you are getting. Thanks!
If you can, please do send the Dockerfile you are using to install the dependencies as well.
Hello, thank you for the reply. Here is the error code I am getting from my discord python bot. I’m trying to play a local audio file but as I execute the command I get the error FFMPEG is not found. I believe its installed but not running. Any help is appreciated!
main Ignoring exception in command whatami:
main Traceback (most recent call last):
main File "/usr/local/lib/python3.9/site-packages/discord/ext/commands/core.py", line 85, in wrapped
main ret = await coro(*args, **kwargs)
main File "/app/main.py", line 116, in whatami
main source = FFmpegPCMAudio('clip5.mp3')
main File "/usr/local/lib/python3.9/site-packages/discord/player.py", line 225, in __init__
main super().__init__(source, executable=executable, args=args, **subprocess_kwargs)
main File "/usr/local/lib/python3.9/site-packages/discord/player.py", line 138, in __init__
main self._process = self._spawn_process(args, **kwargs)
main File "/usr/local/lib/python3.9/site-packages/discord/player.py", line 147, in _spawn_process
main raise ClientException(executable + ' was not found.') from None
main discord.errors.ClientException: ffmpeg was not found.
main
main The above exception was the direct cause of the following exception:
main
main File "/usr/local/lib/python3.9/site-packages/discord/ext/commands/bot.py", line 902, in invoke
main await ctx.command.invoke(ctx)
main File "/usr/local/lib/python3.9/site-packages/discord/ext/commands/core.py", line 864, in invoke
main await injected(*ctx.args, **ctx.kwargs)
main File "/usr/local/lib/python3.9/site-packages/discord/ext/commands/core.py", line 94, in wrapped
main raise CommandInvokeError(exc) from exc
main discord.ext.commands.errors.CommandInvokeError: Command raised an exception: ClientException: ffmpeg was not found.
Here is my dockerfile and requirements.txt:
FROM python:3.9.2
WORKDIR /app
COPY ./requirements.txt /app
ENV PYTHONUNBUFFERED 1
RUN pip3 install --no-cache-dir -r requirements.txt
# really for ever file
# COPY ./main.py .
# COPY ./env.py .
COPY . .
# eviroments
# COPY .env .
CMD ["python", "main.py"]
# CMD ["python", "env.py"]
# CMD ["python", "-m", " discord", "--version"]
# CMD ["ping", "8.8.8.8"]
# CMD ['python', 'main.py']
Requirements.txt
discord.py>=1.6
python-dotenv==0.13.0
ffmpeg-python
python-ffmpeg
ffmpeg
discord.py[voice]>=1.3.0
Hi Andy,
It looks like this package is expecting the ffmpeg application to be installed. Try adding a line to your Dockerfile like:
RUN apt-get update && apt-get install -y ffmpeg
