Hi There,
I’am looking for an Option to switch Balena Audio Client in Standalone Mode if a Device connects via Bluetooth. The Idea behind is, to work as Multiroom Client until a device connects via Bluetooth. The Balena Audio Client should then cut off the Connection to Multiroom Server and play only the Bluetooth Stream. If Bluetooth gets disconnects, then the Balena Audio Client should change to Multiroom Client Mode again an reconnect to Multiroom Server. Is that possible ? Or which component has to be changed to make it possible.
Cheers,
Sascha
