Following the guide at Interacting with the balena Supervisor - Balena Documentation I’m trying to detect when a device has an update in progress, specifically looking for the update_pending, status=Downloading, and download_progress parts.
I’ve found that the only one that seems to reliably get set is update_pending=true. The cloud dashboard happily shows the download progress slider moving across, but looking at the Diagnostics → Supervisor state (which returns identical results to what the app is getting), it has:
{ "api_port": 48484, "ip_address": "10.9.1.31", "os_version": "balenaOS 2.80.3+rev1", "mac_address": "B8:27:EB:70:01:03 B8:27:EB:25:54:56", "supervisor_version": "12.9.3", "update_pending": true, "update_failed": false, "update_downloaded": false, "status": "Idle", "download_progress": null }
I swear I once saw download_progress=0, but I haven’t otherwise seen a status change here from Idle. Obviously the cloud device API sees the download progress fine, but not the supervisor one. The supervisor update_pending goes back false after the container restarts, so it’s not just stuck. The download itself took around 2 minutes on my last run, so it wasn’t just unlucky timing. I’ve watched the supervisor output every 2 seconds during a download and it doesn’t change.
This is on a Pi 3 (64 bit OS), Supervisor 12.9.3, in a single-container app (though deployed/configured with docker-compose.yml).
Is this a supervisor bug or just something to do with my app?
Any guidance appreciated!
