Are there any dependencies between BalenaOS and supervisor versions?
Can I upgrade one without the other completely independently?
Currently most of my Generic_x86 fleet is running balenaOS 2.85.3+rev8 and Supervisor version 12.10.13.
Can I upgrade one without the other in this case?
you can’t downgrade the supervisor back down to the old version pre-update
updating to a new minor version of the supervisor, where the minor version is the digits after the first decimal point in the version number - i.e 12.X.XX should be seamless
updating a to a new major version - e.g 13.X.X in your case, should work - but it is inherently riskier - I would probably advise testing it out first on non production units in your fleet to make sure it works with your application without problems
usually we’d recommend consistantly updating the host OS along with the supervisor - however as above, its worth testing this out on non-production devices just to be sure that it causes no problems for your specific use case
