submitting analytics in offline mode
balena cli tries to send analytics even when offline mode is enabled.
# export BALENARC_OFFLINE_MODE=1
# sudo balena config inject config.json -d balena-rpi4-image.img
Done
Timeout submitting analytics event to balenaCloud/openBalena.
If you are using the balena CLI in an air-gapped environment with a filtered
internet connection, set the BALENARC_OFFLINE_MODE=1 environment variable
when using CLI commands that do not strictly require access to balenaCloud.
Hi, thank you for reporting this, we will look into it. Could you please share with us which version of balena CLI you are running? You can get it by running balena -v
got the same
āžœ balena -v
15.0.3
