I have ran “balenaOS 2.58.0” on STM32MP1 for a while by building it with barys-script in deveoper mode.
However, when I build the image with just the machine argument the image will freeze at Moving /dev, /proc and /sys onto rootfs…
What is wrong or how do I troubleshoot it as I can’t interact via console or balena cloud?
Starting kernel …
Uncompressing Linux... done, booting the kernel.
[ 1.065129] mmc0: unrecognised SCR structure version 4
[ 1.068810] mmc0: error -22 whilst initialising SD card
DEBUG: Loading module debug
DEBUG: Running debug_run
DEBUG: Calling module hook (post): debug_hook_handler
DEBUG: Finished module hook (post): debug_hook_handler
DEBUG: Loading module udev
DEBUG: Calling module hook (pre): debug_hook_handler
DEBUG: Finished module hook (pre): debug_hook_handler
DEBUG: Running udev_run
Unknown filesystem type 62656572 mounted on /sys/fs/cgroup.
Failed to determine root cgroup, ignoring cgroup memory limit: No medium found
starting version 239
device-enumerator: scan all dirs
device-enumerator: scanning /sys/bus
device-enumerator: scanning /sys/class
DEBUG: Loading module prepare
DEBUG: Calling module hook (pre): udev_shutdown_hook_handler
DEBUG: Finished module hook (pre): udev_shutdown_hook_handler
DEBUG: Running prepare_run
DEBUG: Loading module fsuuidsinit
DEBUG: Skipping module fsuuidsinit
DEBUG: Loading module fsck
DEBUG: Running fsck_run
DEBUG: Loading module resindataexpander
DEBUG: Running resindataexpander_run
DEBUG: Loading module rorootfs
DEBUG: Skipping module rorootfs
DEBUG: Loading module rootfs
DEBUG: Running rootfs_run
DEBUG: No e2fs compatible filesystem has been mounted, mounting PARTUUID=3b807b18-a778-408a-bfb8-12ca22a3a220...
DEBUG: Loading module machineid
DEBUG: Running machineid_run
DEBUG: Loading module finish
DEBUG: Running finish_run
DEBUG: Moving /dev, /proc and /sys onto rootfs...
