Working on a multi-container app on the IOT2040 there is some strange behaviour on the download of multi services on resinstaging. I have build 2 services (github.com/bas-prorail/resin-datacollector-edge) and after the successful build (unicorn) there is only one service (s7comm) downloading until it hits approx. 25% then slowing down and completely stopping at 29% (with error TLS handshake timeout) followed by a reset and starting at 0% again. The other one (datacollector-edge) is just showing no download at all, logging 'TLS handshake timeout and then restarting. The logging shows only 14 seconds between ‘downloading’ and ‘failed’.
27.04.18 12:44:52 (+0200) Failed to download image 'registry2.resinstaging.io/v2/818daa5c8aeb81eaa1f06e78b0d57df8@sha256:078abbad982b3479fb976bad74c7ce339b0a62049c23e3a79c4825edbc099720' due to '(HTTP code 500) server error - Get https://registry2.resinstaging.io/v2/v2/818daa5c8aeb81eaa1f06e78b0d57df8/manifests/sha256:078abbad982b3479fb976bad74c7ce339b0a62049c23e3a79c4825edbc099720: Get https://api.resinstaging.io/auth/v1/token?account=d_1fed70a079b29cc347ddbbf73bccd5cc&scope=repository%3Av2%2F818daa5c8aeb81eaa1f06e78b0d57df8%3Apull&service=registry2.resinstaging.io: net/http: TLS handshake timeout '
27.04.18 12:44:56 (+0200) Downloading image 'registry2.resinstaging.io/v2/818daa5c8aeb81eaa1f06e78b0d57df8@sha256:078abbad982b3479fb976bad74c7ce339b0a62049c23e3a79c4825edbc099720'
27.04.18 12:45:10 (+0200) Failed to download image 'registry2.resinstaging.io/v2/818daa5c8aeb81eaa1f06e78b0d57df8@sha256:078abbad982b3479fb976bad74c7ce339b0a62049c23e3a79c4825edbc099720' due to '(HTTP code 500) server error - Get https://registry2.resinstaging.io/v2/v2/818daa5c8aeb81eaa1f06e78b0d57df8/manifests/sha256:078abbad982b3479fb976bad74c7ce339b0a62049c23e3a79c4825edbc099720: Get https://api.resinstaging.io/auth/v1/token?account=d_1fed70a079b29cc347ddbbf73bccd5cc&scope=repository%3Av2%2F818daa5c8aeb81eaa1f06e78b0d57df8%3Apull&service=registry2.resinstaging.io: net/http: TLS handshake timeout '
27.04.18 12:45:14 (+0200) Downloading image 'registry2.resinstaging.io/v2/818daa5c8aeb81eaa1f06e78b0d57df8@sha256:078abbad982b3479fb976bad74c7ce339b0a62049c23e3a79c4825edbc099720'
27.04.18 12:45:28 (+0200) Failed to download image 'registry2.resinstaging.io/v2/818daa5c8aeb81eaa1f06e78b0d57df8@sha256:078abbad982b3479fb976bad74c7ce339b0a62049c23e3a79c4825edbc099720' due to '(HTTP code 500) server error - Get https://registry2.resinstaging.io/v2/v2/818daa5c8aeb81eaa1f06e78b0d57df8/manifests/sha256:078abbad982b3479fb976bad74c7ce339b0a62049c23e3a79c4825edbc099720: Get https://api.resinstaging.io/auth/v1/token?account=d_1fed70a079b29cc347ddbbf73bccd5cc&scope=repository%3Av2%2F818daa5c8aeb81eaa1f06e78b0d57df8%3Apull&service=registry2.resinstaging.io: net/http: TLS handshake timeout '
27.04.18 12:45:34 (+0200) Downloading image 'registry2.resinstaging.io/v2/818daa5c8aeb81eaa1f06e78b0d57df8@sha256:078abbad982b3479fb976bad74c7ce339b0a62049c23e3a79c4825edbc099720'
27.04.18 12:45:49 (+0200) Failed to download image 'registry2.resinstaging.io/v2/818daa5c8aeb81eaa1f06e78b0d57df8@sha256:078abbad982b3479fb976bad74c7ce339b0a62049c23e3a79c4825edbc099720' due to '(HTTP code 500) server error - Get https://registry2.resinstaging.io/v2/v2/818daa5c8aeb81eaa1f06e78b0d57df8/manifests/sha256:078abbad982b3479fb976bad74c7ce339b0a62049c23e3a79c4825edbc099720: Get https://api.resinstaging.io/auth/v1/token?account=d_1fed70a079b29cc347ddbbf73bccd5cc&scope=repository%3Av2%2F818daa5c8aeb81eaa1f06e78b0d57df8%3Apull&service=registry2.resinstaging.io: net/http: TLS handshake timeout '
27.04.18 12:45:55 (+0200) Downloading image 'registry2.resinstaging.io/v2/818daa5c8aeb81eaa1f06e78b0d57df8@sha256:078abbad982b3479fb976bad74c7ce339b0a62049c23e3a79c4825edbc099720'
When pulling the 2 services apart and downloading each (one after the other) as ‘main’ single service they are downloading and started as expected. Striking difference between ‘multi-service’ and ‘single service’ is that in single service it takes about 1-2 minutes before downloading starts after showing ‘main – downloading - 0%’, so I would expect that ‘multi-service’ does the same but after 14 sec. it restarts.
I’m working with resinstaging because the IOT2000 image on this platform is supporting multi-container, the OS is 2.12.5+rev2 with a fresh factorybuild uSD (CL10, 16GB) I have tried also another uSD but have the same issue.
@imrehg Any suggestions on how to solve this?
Thank you, Bas
