I am trying to share memory between two containers by making container A’s memory shareable and allowing container B to access it.
This works outside of balena if I start the containers individually and use the following commands.
docker run --privileged --network host --ipc:shareable containerA
docker run --privileged --network host --ipc:container:<id_of_containerA> containerB
However, when I now try to start this with the following docker-compose.yml in a Balena application, container B does not start and only gives the status “downloaded”.
The documentation of balena directs me to the one of docker for the “ipc” flag, which says that the docker-compose should be working the same way as the regular docker commands.
The only difference between the two commands and the docker-compose would be the “service:containername” part which I think needs to be done, since I don’t know the container ID in advance.
Do you have any ideas what this could be or where I should look?
Hi there - looking at the docs (Docker run reference | Docker Documentation), it seems you should be able to use ipc: "container:containerA" in your docker compose for containerB. Where does it say that you must use the container id only, or have to substitute container to service?
Alternatively, does ipc: "host" satisfy your use case?
Yes the ipc: "host" satisfy the needs for now. It would only be nice with the specified container to gain some control over the container. We will test it and report back.
While ipc: host is a work-around, it would still be good for security purposes, to support the shareable IPC model. Currently, setting ipc: service:<<name>> fails to start a container with (HTTP code 500) server error - Invalid IPC mode: service:gpsd error:
[error] Scheduling another update attempt in 1000ms due to failure: Error: Failed to apply state transition steps. (HTTP code 500) server error - Invalid IPC mode: service:gpsd Steps:["start"]
[error] at /usr/src/app/dist/app.js:16:12744
[error] at process.processTicksAndRejections (node:internal/process/task_queues:105:5)
[error] Device state apply error Error: Failed to apply state transition steps. (HTTP code 500) server error - Invalid IPC mode: service:gpsd Steps:["start"]
[info] Applying target state
[event] Event: Service start {"service":{"appId":..
Using ipc: container:<<name>> is not an option, since this name is dynamic.
Also, balena service ls is not a valid command for the engine, which makes me think this is by design/not supported and the docs should be updated to reflect that.
Fr reference, the redacted compose file for reproduction(s):
