Setting Default Jetson Energy Mode (nvpmodel) progamatically
Hi!
I am using Balena with a Jetson Xavier and wonder if there is a way to set the default energy mode such that when I flash a device it automatically launches with this energy mode.
The default energy mode is set to 2, while I want it to be set to 0.
Currently I have to manually ssh into the HostOS and edit the file at /etc/nvpmodel.conf such that < PM_CONFIG DEFAULT=0 >, but this becomes cumbersome if you are looking to launch a lot of devices.
Thanks! :slight_smile:
We currently do not expose an easy way to achieve that.
It sounds useful though to be able to do by using a device configuration variable in the balenaCloud dashboard.
I’ve opened an internal issue for this to track this request and gave a note to the respective internal teams.
We will let you know when we have updates on this.
Kind regards,
Thodoris
Hi @uvaaland
You can also have a look at this option of adding a udev rule: Nvpmodel not installed on Jetson TX2 yocto image
Thanks for bringing this to my attention! I might be able to do with this for now :+1:
Hello there, any progress on this front?
We are still doing this one: Nvpmodel not installed on Jetson TX2 yocto image - #15 by rapha
