Set starting date of balena
Hello
I have a problem with NTP and chrony time sync in my environment, so device can’t properly register to openbalena (cause of certificate is not yet valid)
Is there an option to set the starting date of balena os?
So device will start with 29 JUL instead of 5 FEB at first startup
Without this my devices can’t log in into balena, and i can’t login to vpn for example
unfortunately at this moment it is only possible to do this manually on development images accessing the device via ssh on port 22222 or the console. We are working on an alternative for environments where NTP is not available but it is not ready yet: https://github.com/balena-os/meta-balena/issues/1337
When you say problem with NTP and chrony - is this because you are not able to access any NTP server or is this only the default ones? If you have some reachable NTP server on the local network you could specify it in config.json and the device would prefer it over the default ones. https://www.balena.io/docs/reference/OS/configuration/#sample-configjson
Hello
I don’t really know what is a problem here,
Time is just not synced
I tried a lot of commands
chronyc tracking
Ref erence ID : 00000000 ()
Stratum : 0
Ref time (UTC) : Thu Jan 01 00:00:00 1970
System time : 0.000000000 seconds fast of NTP time
Last offset : +0.000000000 seconds
RMS offset : 0.000000000 seconds
Frequency : 0.000 ppm slow
Residual freq : +0.000 ppm
Skew : 0.000 ppm
Root delay : 1.000000000 seconds
Root dispersion : 1.000000000 seconds
Update interval : 0.0 seconds
Leap status : Not synchronised
chronyc sources
root@2ce005f:~# chronyc sources
210 Number of sources = 4
MS Name/IP address Stratum Poll Reach LastRx Last sample
^? ntp2.tktelekom.pl 0 14 100 - +0ns[ +0ns] +/- 0ns
^? time.cloudflare.com 0 14 100 - +0ns[ +0ns] +/- 0ns
^? dc1-recdns02.bellmtsdata> 0 14 100 - +0ns[ +0ns] +/- 0ns
^? news-archive.icm.edu.pl 0 14 100 - +0ns[ +0ns] +/- 0ns
chronyc makestep
200 OK
I really don’t know what can be an issue here
Local server also doesn’t work
thanks for coming back. So looking at the logs it really looks like the device can not access the NTP servers. Taking one step back - can you please confirm that your device has a working internet connection and working DNS? Are you able to ping any of the listed time servers - ntp2.tktelekom.pl, time.cloudflare.com, news-archive.icm.edu.pl (I assume the truncated one is dc1-recdns02.bellmtsdatacenters.com but let’s not rely on that one)?
Hi i just reflashed devices
new sources:
^? ip-159-253-242-123.rev.s> 0 14 40 - +0ns[ +0ns] +/- 0ns
^? 46.175.224.7.maxnet.net.> 0 14 40 - +0ns[ +0ns] +/- 0ns
^? ntp2.tktelekom.pl 0 14 40 - +0ns[ +0ns] +/- 0ns
^? 96-7.cpe.smnt.pl 0 14 40 - +0ns[ +0ns] +/- 0ns
pings:
root@3772483:~# ping 96-7.cpe.smnt.pl
PING 96-7.cpe.smnt.pl (94.154.96.7): 56 data bytes
64 bytes from 94.154.96.7: seq=0 ttl=55 time=13.468 ms
64 bytes from 94.154.96.7: seq=1 ttl=55 time=14.099 ms
root@3772483:~# ping 46.175.224.7.maxnet.net.pl
PING 46.175.224.7.maxnet.net.pl (46.175.224.7): 56 data bytes
64 bytes from 46.175.224.7: seq=0 ttl=55 time=15.634 ms
64 bytes from 46.175.224.7: seq=1 ttl=55 time=14.917 ms
root@3772483:~# ping ip-159-253-242-123.rev.snt.net.pl
PING ip-159-253-242-123.rev.snt.net.pl (159.253.242.123): 56 data bytes
64 bytes from 159.253.242.123: seq=0 ttl=58 time=8.092 ms
64 bytes from 159.253.242.123: seq=1 ttl=58 time=7.983 ms
tktelekom has timed out
root@3772483:~# ping ntp2.tktelekom.pl
PING ntp2.tktelekom.pl (213.199.225.40): 56 data bytes
^C
— ntp2.tktelekom.pl ping statistics —
2 packets transmitted, 0 packets received, 100% packet loss
thanks, so it really looks like NTP access is blocked, in that case unfortunately there is no better solution than manually setting up the time or trying local NTP servers in config.json if you are able to get some from your connection provider or network administrator. As I said - this is a known issue and we are actively working on it.
You can try installing ntpdate in a container and run ntpdate ntp2.tktelekom.pl (or any other ntp server) and see if it works.
It works in this case
apt install -y ntpdate
root@889e29ff8df0:/app# ntpdate ntp2.tktelekom.pl
29 Jul 13:46:14 ntpdate[18]: step time server 213.199.225.40 offset 15139717.831731 sec
root@889e29ff8df0:/app# date
Wed Jul 29 13:46:16 UTC 2020
Very strange
Can you check chronyd logs with journalctl -u chronyd ?
Yes
– Logs begin at Fri 2020-01-31 09:20:37 UTC, end at Wed 2020-07-29 14:07:21 UTC. –
Feb 05 08:16:55 localhost chronyd[687]: 2020-02-05T08:16:55Z chronyd version 3.4 starting (+CMDMON +NTP +REFCLOCK +RTC -PRIVDROP -SCFILTER -SIGND +ASYNCDNS -SECHASH +IPV6 -DEBUG)
Jul 29 13:46:40 3772483 chronyd[687]: 2020-07-29T13:46:40Z Forward time jump detected!
It looks like it works fine according to these logs.
Is the output of date correct ?
Is chronyc tracking still saying that it is not synchronized ?
Hi, date is correct, chronyc tracking not
root@3772483:~# chronyc tracking
Reference ID : 00000000 ()
Stratum : 0
Skew : 0.000 ppm
date:
root@3772483:~# date
Wed Jul 29 14:25:28 UTC 2020
I guess the time is correct only because you set it manually then.
Can you try the following:
systemctl stop chronyd
chronyd -q 'server pool.ntp.org iburst'
(or any other ntp server than pool.ntp.org)
root@3772483:~# chronyd -q “server pool.ntp.org iburst”
2020-07-29T14:36:26Z chronyd version 3.4 starting (+CMDMON +NTP +REFCLOCK +RTC -PRIVDROP -SCFILTER -SIGND +ASYNCDNS -SECHASH +IPV6 -DEBUG)
2020-07-29T14:36:38Z No suitable source for synchronisation
2020-07-29T14:36:38Z chronyd exiting
root@3772483:~# chronyd -q “server 0.resinio.pool.ntp.org iburst”
2020-07-29T14:37:22Z chronyd version 3.4 starting (+CMDMON +NTP +REFCLOCK +RTC -PRIVDROP -SCFILTER -SIGND +ASYNCDNS -SECHASH +IPV6 -DEBUG)
2020-07-29T14:37:49Z No suitable source for synchronisation
2020-07-29T14:37:49Z chronyd exiting
root@3772483:~# chronyd -q “server pl.pool.ntp.org iburst”
2020-07-29T14:38:13Z chronyd version 3.4 starting (+CMDMON +NTP +REFCLOCK +RTC -PRIVDROP -SCFILTER -SIGND +ASYNCDNS -SECHASH +IPV6 -DEBUG)
2020-07-29T14:38:26Z No suitable source for synchronisation
2020-07-29T14:38:26Z chronyd exiting
root@3772483:~# chronyd -q “server ntp2.tktelekom.pl iburst”
2020-07-29T14:38:45Z chronyd version 3.4 starting (+CMDMON +NTP +REFCLOCK +RTC -PRIVDROP -SCFILTER -SIGND +ASYNCDNS -SECHASH +IPV6 -DEBUG)
2020-07-29T14:38:56Z No suitable source for synchronisation
2020-07-29T14:38:56Z chronyd exiting
This is quite strange: ntpdate ntp2.tktelekom.pl works but chronyd -q "server ntp2.tktelekom.pl iburst" doesn’t.
Can you try passing -4 or -6 to the chronyd command ?
Yes it’s strange
root@3772483:~# chronyd -4 -q “server ntp2.tktelekom.pl iburst”
2020-07-29T14:49:15Z chronyd version 3.4 starting (+CMDMON +NTP +REFCLOCK +RTC -PRIVDROP -SCFILTER -SIGND +ASYNCDNS -SECHASH +IPV6 -DEBUG)
2020-07-29T14:49:25Z No suitable source for synchronisation
2020-07-29T14:49:25Z chronyd exiting
root@3772483:~# chronyd -6 -q “server ntp2.tktelekom.pl iburst”
2020-07-29T14:49:40Z chronyd version 3.4 starting (+CMDMON +NTP +REFCLOCK +RTC -PRIVDROP -SCFILTER -SIGND +ASYNCDNS -SECHASH +IPV6 -DEBUG)
2020-07-29T14:49:50Z No suitable source for synchronisation
2020-07-29T14:49:50Z chronyd exiting
root@3772483:~# chronyd -6 -4 -q “server ntp2.tktelekom.pl iburst”
2020-07-29T14:50:04Z chronyd version 3.4 starting (+CMDMON +NTP +REFCLOCK +RTC -PRIVDROP -SCFILTER -SIGND +ASYNCDNS -SECHASH +IPV6 -DEBUG)
2020-07-29T14:50:14Z No suitable source for synchronisation
2020-07-29T14:50:14Z chronyd exiting
root@3772483:~# chronyd -6 -4 -q “server pool.ntp.org iburst”
2020-07-29T14:55:17Z chronyd version 3.4 starting (+CMDMON +NTP +REFCLOCK +RTC -PRIVDROP -SCFILTER -SIGND +ASYNCDNS -SECHASH +IPV6 -DEBUG)
2020-07-29T14:55:27Z No suitable source for synchronisation
2020-07-29T14:55:27Z chronyd exiting
ntpdate still works
root@889e29ff8df0:/app# ntpdate pool.ntp.org
29 Jul 14:54:56 ntpdate[17]: step time server 34.194.39.113 offset 230.527345 sec
29 Jul 14:55:07 ntpdate[18]: adjust time server 34.194.39.113 offset -0.000257 sec
root@889e29ff8df0:/app# exit
I guess the next step would be to install chrony and tcpdump in the same container as ntpdate and run tcpdump -i <interface name> udp port 123 -vv -X while trying to sync date with both commands and compare the output.
chronyd
ntpdate
I get a 404 for both urls
I just edited the links
