I have installed Balena + Screenly OSE on a Raspberry Pi3 but Screenly is not starting. I get the Balena logo screen but then nothing. I am getting the following messages in the Balena Dashboard:
09.12.20 14:32:52 (+0000) screenly-viewer Still continue…
09.12.20 14:32:52 (+0000) screenly-celery [2020-12-09 14:32:52,868: ERROR/MainProcess] consumer: Cannot connect to redis://redis:6379/0: DENIED Redis is running in protected mode because protected mode is enabled, no bind address was specified, no authentication password is requested to clients. In this mode connections are only accepted from the loopback interface. If you want to connect from external computers to Redis you may adopt one of the following solutions: 1) Just disable protected mode sending the command ‘CONFIG SET protected-mode no’ from the loopback interface by connecting to Redis from the same host the server is running, however MAKE SURE Redis is not publicly accessible from internet if you do so. Use CONFIG REWRITE to make this change permanent. 2) Alternatively you can just disable the protected mode by editing the Redis configuration file, and setting the protected mode option to ‘no’, and then restarting the server. 3) If you started the server manually just for testing, restart it with the ‘–protected-mode no’ option. 4) Setup a bind address or an authentication password. NOTE: You only need to do one of the above things in order for the server to start accepting connections from the outside…
I have edited the redis.config file and set “protected mode no” and restarted redis and rebooted the device but this seems to make no difference.
The Pi has previously run ScreenlyOSE as a local install but i really need to be able to manage it remotely.
Any help gratefully received.
