So i’m trying to run a Ruby on Rails container to be accessed through the public URL, which means I need either to run it on port 80 or use Nginx (or similar tool) to redirect calls on port 80 to the port used in the Rails container, I’m trying using Nginx but haven’t been able to make it run, I get the error:
failed (111: Connection refused) while connecting to upstream, client: 52.4.252.97, server: ruby_test, request: "GET / HTTP/1.1", upstream: "http://0.0.0.0:3000/"
My docker-compose file looks like:
version: '2'
services:
ruby_test:
build: ./ruby_test
privileged: true
expose:
- "3000"
nginx:
build: ./nginx
depends_on:
- ruby_test
ports:
- "80:80"
My nginx.conf file looks like:
events {
worker_connections 1024;
http {
upstream ruby_test {
server 0.0.0.0:3000;
include mime.types;
default_type application/octet-stream;
sendfile on;
keepalive_timeout 65;
server {
listen 80;
server_name ruby_test;
location / {
proxy_pass http://ruby_test;
#root html;
#index index.html index.htm;
error_page 500 502 503 504 /50x.html;
location = /50x.html {
root html;
include servers/*;
… I know the rails container is runing well on port 3000 because I can curl localhost:3000 and get the response expected.
Also I know nginx.conf file is fine give I tried it locally ad it works.
Ant ideas what am I missing?
