cd base-image
git submodule init
git submodule update
But I get this error when I try to build it using the build.sh :
ERROR: No recipes available for:
/mnt/data/mbx-wpe/base-image/build/../meta-resin-wpe/recipes-wpe/wpebackend-rdk/wpebackend-rdk_0.1.bbappend
/mnt/data/mbx-wpe/base-image/build/../meta-resin-wpe/recipes-wpe/wpewebkit/wpewebkit_0.1.bbappend
Hey @samoud, at what stage does that message appear?
Just did a new clone with git clone https://github.com/resin-io-playground/resin-wpe --recursive (which clones the submodules in one go), setup a python2 virtualenv, and run the ./build.sh script. The build started fine, parsed all the recipes successfully. So I’m guessing the code might not be checked out fully for you? Could you do a new clone, and try from there, to test? (and we’ll do the build ourselves as well, to see what’s up)
