I have a docker-compose with multiple services. Most of them are defined as network_mode: bridge and the others as host.
One of the containers used is linuxserver/swag as reversed proxy. According to all documentation I should be able to use the container name to direct to another container. For example in the proxy conf:
set $upstream_app homeassistant;
set $upstream_port 8123;
set $upstream_proto http;
proxy_pass $upstream_proto://$upstream_app:$upstream_port;
However as long as homeassistant is there (which is there as container) it doesn’t work. It only works when I replace it with an IP.
If I do nslookup [container] from within any of the containers and picking a random other container the only thing I get is:
nslookup mosquitto
Server: 10.114.102.1
Address: 10.114.102.1#53
Non-authoritative answer:
*** Can't find mosquitto: No answer
or
nslookup ebusd
Address: 10.114.102.1:53
To my understanding this should be resolved by resin-dns which is 10.114.102.1; now I’m wondering why this isn’t working?
