Any body has problem with libgpiod_pulsein in raspberry4? when my script try to execute, it complained No such file or directory.
The file is actually there: in
/usr/local/lib/python3.7/site-packages/adafruit_blinka/microcontroller/bcm283x/pulseio
Try to execute it directly under the path directory, spewed out the same error: No such file or directory.
Anybody?
JS
Hello JS, I’m not aware of other users having this issue. Could it be this issue? : https://learn.adafruit.com/circuitpython-on-google-coral-linux-blinka/faq-troubleshooting#faq-3048170
Could you share your script, and the exact error message?
Hi:
Managed to get it working, at last.
The problem is adafruit-circuit [blinka, dht, etc] are not ready to run on balena-os for raspberry pi 4 [balena-lib/ debian rasperry python]
So, here is trick:
in the docker file, include the followings:
dpkg --add-architecture armhf
apt-get update
apt-get install libc6:armhf libstdc++6:armhf
and instead of installing libgpiod2: install libgpiod2:armhf
apt-get install libgpiod2:armhf
regards,
juniarto
Thanks for the follow up, great information for others with the same issue.
