We have a multi-container application where 1 container is accessing USB phidget devices. Upon boot the USB devices are detected and run normally. If the devices are unplugged and plugged back in the phidget application sees the devices plugged back in but cannot open the usb as can be seen in the following logs. Any ideas on how to fix this?
Logs where phidget application cannot open the USB
2021-09-14T21:36:11 <Info> phidget22usb[PhidgetUSBScanDevices()] : New Phidget found in PhidgetUSBBuildList: 1/4
2021-09-14T21:36:11 <Warn> phidget22usb[PhidgetUSBScanDevices()] : libusb_open() failed: LIBUSB_ERROR_NO_DEVICE - No such device (it may have been disconnected).
2021-09-14T21:36:11 <Info> phidget22usb[PhidgetUSBScanDevices()] : This usually means you need to run as root, or install the udev rules.
2021-09-14T21:36:11 <Info> phidget22usb[PhidgetUSBScanDevices()] : New Phidget found in PhidgetUSBBuildList: 1/5
2021-09-14T21:36:12 <Info> phidget22usb[PhidgetUSBScanDevices()] : New Phidget found in PhidgetUSBBuildList: 1/7
2021-09-14T21:36:12 <Warn> phidget22usb[PhidgetUSBScanDevices()] : libusb_open() failed: LIBUSB_ERROR_NO_DEVICE - No such device (it may have been disconnected).
2021-09-14T21:36:12 <Info> phidget22usb[PhidgetUSBScanDevices()] : This usually means you need to run as root, or install the udev rules.
Things we have tried
Setting the service to privileged mode and the following…
We have tried enabling UDEV=1 in the compose file and dockerfile.template. When we do this we can see the systemd-udevd process running (in top). But we only see kernel events but no UDEV events.
We have tried running UDEV=0, and starting /lib/systemd/systemd-udevd --daemon in our dockerfile CMD. When we do this, we see udevadmn monitor UDEV events. But we still get the errors show above.
Here is a partial log of the UDEV events coming from udevadm monitor:
KERNEL[279.664196] add /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4.7 (usb)
KERNEL[279.665966] add /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4.7/1-1.4.7:1.0 (usb)
KERNEL[279.670201] add /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4.7/1-1.4.7:1.0/0003:06C2:003F.0006 (hid)
KERNEL[279.670723] add /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4.7/1-1.4.7:1.0/usbmisc/hiddev2 (usbmisc)
KERNEL[279.670800] add /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4.7/1-1.4.7:1.0/0003:06C2:003F.0006/hidraw/hidraw2 (hidraw)
KERNEL[279.684558] bind /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4.7/1-1.4.7:1.0/0003:06C2:003F.0006 (hid)
KERNEL[279.684653] bind /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4.7/1-1.4.7:1.0 (usb)
KERNEL[279.684727] bind /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4.7 (usb)
UDEV [279.690442] add /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4.7 (usb)
UDEV [279.692619] add /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4.7/1-1.4.7:1.0 (usb)
UDEV [279.696777] add /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4.7/1-1.4.7:1.0/0003:06C2:003F.0006 (hid)
UDEV [279.702063] add /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4.7/1-1.4.7:1.0/usbmisc/hiddev2 (usbmisc)
UDEV [279.707213] add /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4.7/1-1.4.7:1.0/0003:06C2:003F.0006/hidraw/hidraw2 (hidraw)
UDEV [279.713770] bind /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4.7/1-1.4.7:1.0/0003:06C2:003F.0006 (hid)
UDEV [279.715866] bind /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4.7/1-1.4.7:1.0 (usb)
UDEV [279.718781] bind /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4.7 (usb)
Here is our udev rules file:
# Very old Phidgets
SUBSYSTEMS=="usb", ACTION=="add", ATTRS{idVendor}=="0925", ATTRS{idProduct}=="8101", MODE="666"
SUBSYSTEMS=="usb", ACTION=="add", ATTRS{idVendor}=="0925", ATTRS{idProduct}=="8104", MODE="666"
SUBSYSTEMS=="usb", ACTION=="add", ATTRS{idVendor}=="0925", ATTRS{idProduct}=="8201", MODE="666"
# All current and future Phidgets - Vendor = 0x06c2, Product = 0x0030 - 0x00af
SUBSYSTEMS=="usb", ACTION=="add", ATTRS{idVendor}=="06c2", ATTRS{idProduct}=="00[3-a][0-f]", MODE="666"
# SPI VINT Hub
SUBSYSTEMS=="spi", DRIVERS=="phidget_hub0004", ACTION=="add", MODE="666
Here is our dockerfile for the service:
FROM balenalib/%%BALENA_MACHINE_NAME%%:latest-run as run
WORKDIR /usr/src/phidget
RUN set -ex; \
tempPkgs=' \
ca-certificates \
wget \
unzip \
apt-get update; \
apt-get install -q -y --no-install-recommends \
$tempPkgs; \
wget https://www.phidgets.com/downloads/phidget22/libraries/linux/libphidget22/libphidget22-1.7.20210816.tar.gz; \
wget https://www.phidgets.com/downloads/phidget22/libraries/linux/libphidget22extra/libphidget22extra-1.7.20210816.tar.gz; \
wget https://www.phidgets.com/downloads/phidget22/servers/linux/phidget22networkserver/phidget22networkserver-1.7.20210816.tar.gz; \
# Cleanup tempPkgs
apt-get purge -y --auto-remove $tempPkgs; \
# Install persistend packages
apt-get update; \
build-essential \
usbutils \
libusb-1.0-0-dev \
apt-get autoremove -q -y; \
apt-get clean -q -y; \
rm -rf /var/lib/apt/lists/*; \
# Phidget 22 Library
tar -xzf libphidget22-*.tar.gz; \
cd libphidget22*; \
./configure --prefix=/usr; \
make -j; \
make -j install; \
cd ..; \
# Phidget 22 Library Extra
tar -xzf libphidget22extra-*.tar.gz; \
cd libphidget22extra*; \
make -j; \
make -j install; \
cd ..; \
# Phidget 22 Network Server
tar -xzf phidget22networkserver-*.tar.gz; \
cd phidget22networkserver*; \
make -j; \
make -j install
# Config
COPY ./phidget22networkserver.pc /etc/phidgets/phidget22networkserver.pc
COPY ./99-libphidget22.rules /etc/udev/rules.d
# Cleanup
RUN rm -rf libphidget22*; \
rm -rf phidget22networkserver*
CMD /lib/systemd/systemd-udevd --daemon && phidget22networkserver
Docker compose file
version: '2'
volumes:
solvere-data:
services:
log:
build: log
expose:
- '80'
volumes:
- 'solvere-data:/data'
phidget:
build: phidget
expose:
- '5661'
volumes:
privileged: true
labels:
io.balena.features.kernel-modules: true
api:
build: api
expose:
- '3000'
volumes:
privileged: true
labels:
io.balena.features.supervisor-api: true
depends_on:
- log
- phidget
# - db
app:
build: app
volumes:
privileged: true
labels:
depends_on:
- log
