Persistent data across multicontainers
I have used within a container the /data path for persistent data across reboots, eg logs. I know that this mount is associated with my container from the point of view of the host
balenaOS.
Now that I’m using a multicontainer solution, how do I exchange data that I want to persist between containers across reboots? Eg, container one captures frames from a camera and sends them to container two.
Hey @jason10,
You can achieve this by using something called named-volume.
Take a look at this docker-compose.yml file as reference:
You have a volume:
volumes:
  data-volume:
And on each container, you add - data-volume:/containers-shared
Hope this helps!
Cheers
Also worth having a look at the documentation for named volumes:
