Hi, I will first explain behaviour of this problem that happens on Balena Cloud.
1 - I have an application where the account user A is owner
2 - I decided to add a 2nd user B as developer
3 - User receives mail/link and when it clicks it is looged in as A
4 - Application >members instead of having user A (owner) and B (developper) presents on table members A (owner) and A (developper)
5 - I proceed to delete A (developper) so that i can go through the process of creating again a user developer
6 - Balena deletes both A (owner) and A (developer)
This is the 1st problem.
7 - Now for some reason A which is owner of the account can’t create new applications because everytime he tries to create a new application in the Dialog box the option “Application Type” doesn’t appear to be filled.
This is the 2nd problem. It’s worse because i cannot carry on with using the platform.
The 1st just leaves an orphan Application.
Can you help me support. If you need more informatio let me know, i can give you the account A i was talking about.
For the first problem: we are currently working on a fix, in the meantime, please make sure to log out before clicking an invitation link.
Do you need us to add [masked email] back to wisebox2020-test ?
About the second problem:
Does it only happen with that specific user ?
Do you see anything when you click on the dropdown button ?
Hi there – thanks again for getting in touch with us. We believe we have resolved this problem with your account; can you please check that it looks good at your end?
In addition, we are adding a change to our API that should prevent this from happening again.
Hi @suporte,
We have a PR in progress to prevent this kind of thing from happening again, it will take a couple of days until we have it tested and deployed.
Please let us know if you encounter any similar issues in the future.
