orange pi zero doesnt recover from wifi outaage
No worries, just in case there is nothing evident in the logs, another suggestion would be to try and disable the on-board WLAN on the OPi, since there are reports of it being unstable and instead use an external USB adapter. Failing that, another workaround may be to wire up a watchdog type script to run periodically on the device, checking for network connectivity and manually reconnecting if detected offline.
