openBalena API errors in log
Hi, can anyone help explain what might be causing the following errors in the open-balena-api docker logs?
Sep 08 20:54:57 6d08b4fa21b1 api[1061]: Failed to get device type build data for rt-rpi-300/2.75.0+rev1.dev Access Denied AccessDenied: Access Denied
Sep 08 20:54:57 6d08b4fa21b1 api[1061]:     at Request.extractError (/usr/src/app/node_modules/aws-sdk/lib/services/s3.js:718:35)
Sep 08 20:54:57 6d08b4fa21b1 api[1061]:     at Request.callListeners (/usr/src/app/node_modules/aws-sdk/lib/sequential_executor.js:106:20)
Sep 08 20:54:57 6d08b4fa21b1 api[1061]:     at Request.emit (/usr/src/app/node_modules/aws-sdk/lib/sequential_executor.js:78:10)
Sep 08 20:54:57 6d08b4fa21b1 api[1061]:     at Request.emit (/usr/src/app/node_modules/aws-sdk/lib/request.js:688:14)
Sep 08 20:54:57 6d08b4fa21b1 api[1061]:     at Request.transition (/usr/src/app/node_modules/aws-sdk/lib/request.js:22:10)
Sep 08 20:54:57 6d08b4fa21b1 api[1061]:     at AcceptorStateMachine.runTo (/usr/src/app/node_modules/aws-sdk/lib/state_machine.js:14:12)
Sep 08 20:54:57 6d08b4fa21b1 api[1061]:     at /usr/src/app/node_modules/aws-sdk/lib/state_machine.js:26:10
Sep 08 20:54:57 6d08b4fa21b1 api[1061]:     at Request.<anonymous> (/usr/src/app/node_modules/aws-sdk/lib/request.js:38:9)
Sep 08 20:54:57 6d08b4fa21b1 api[1061]:     at Request.<anonymous> (/usr/src/app/node_modules/aws-sdk/lib/request.js:690:12)
Sep 08 20:54:57 6d08b4fa21b1 api[1061]:     at Request.callListeners (/usr/src/app/node_modules/aws-sdk/lib/sequential_executor.js:116:18)
Sep 08 20:54:57 6d08b4fa21b1 api[1061]:     at callNextListener (/usr/src/app/node_modules/aws-sdk/lib/sequential_executor.js:96:12)
Sep 08 20:54:57 6d08b4fa21b1 api[1061]:     at IncomingMessage.onEnd (/usr/src/app/node_modules/aws-sdk/lib/event_listeners.js:313:13)
Sep 08 20:54:57 6d08b4fa21b1 api[1061]:     at IncomingMessage.emit (events.js:327:22)
Sep 08 20:54:57 6d08b4fa21b1 api[1061]:     at IncomingMessage.EventEmitter.emit (domain.js:467:12)
Sep 08 20:54:57 6d08b4fa21b1 api[1061]:     at endReadableNT (internal/streams/readable.js:1327:12)
Sep 08 20:54:57 6d08b4fa21b1 api[1061]:     at processTicksAndRejections (internal/process/task_queues.js:80:21)
Sep 08 20:54:57 6d08b4fa21b1 api[1061]: Failed to get device type build data for imx8mm-var-dart-plt/2.80.5+rev1.dev Access Denied AccessDenied: Access Denied
Sep 08 20:54:57 6d08b4fa21b1 api[1061]: Failed to get device type build data for imx8mmrom5721a1/2.75.0+rev2.dev Access Denied AccessDenied: Access Denied
Sep 08 20:54:57 6d08b4fa21b1 api[1061]: Failed to get device type build data for imx8mmebcrs08a1/2.80.5+rev1.dev Access Denied AccessDenied: Access Denied
Sep 08 20:54:57 6d08b4fa21b1 api[1061]: Failed to get device type build data for pc-20/2.69.1+rev3.dev Access Denied AccessDenied: Access Denied
Hi there, these errors are thrown because the enumerated list of device types includes some, which are private and therefore not publicly accessible. Are these errors causing any functionality loss (they shouldn’t be)?
Hi @ab77, thanks for the response. I don’t think they are causing any issues, just something I came across when troubleshooting another issue.
Regards,
Gerard.
I am also having these errors.
Nov 19 00:04:40 46b4273b4079 api[1060]: Failed to get device type build data for imx8mm-var-dart-nrt/2.60.1+rev3.dev Access Denied AccessDenied: Access Denied
Nov 19 00:04:40 46b4273b4079 api[1060]: at Request.extractError (/usr/src/app/node_modules/aws-sdk/lib/services/s3.js:718:35)
Nov 19 00:04:40 46b4273b4079 api[1060]: at Request.callListeners (/usr/src/app/node_modules/aws-sdk/lib/sequential_executor.js:106:20)
Nov 19 00:04:40 46b4273b4079 api[1060]: at Request.emit (/usr/src/app/node_modules/aws-sdk/lib/sequential_executor.js:78:10)
Nov 19 00:04:40 46b4273b4079 api[1060]: at Request.emit (/usr/src/app/node_modules/aws-sdk/lib/request.js:688:14)
Nov 19 00:04:40 46b4273b4079 api[1060]: at Request.transition (/usr/src/app/node_modules/aws-sdk/lib/request.js:22:10)
Nov 19 00:04:40 46b4273b4079 api[1060]: at AcceptorStateMachine.runTo (/usr/src/app/node_modules/aws-sdk/lib/state_machine.js:14:12)
Nov 19 00:04:40 46b4273b4079 api[1060]: at /usr/src/app/node_modules/aws-sdk/lib/state_machine.js:26:10
Nov 19 00:04:40 46b4273b4079 api[1060]: at Request. (/usr/src/app/node_modules/aws-sdk/lib/request.js:38:9)
Nov 19 00:04:40 46b4273b4079 api[1060]: at Request. (/usr/src/app/node_modules/aws-sdk/lib/request.js:690:12)
Nov 19 00:04:40 46b4273b4079 api[1060]: at Request.callListeners (/usr/src/app/node_modules/aws-sdk/lib/sequential_executor.js:116:18)
Nov 19 00:04:40 46b4273b4079 api[1060]: at callNextListener (/usr/src/app/node_modules/aws-sdk/lib/sequential_executor.js:96:12)
Nov 19 00:04:40 46b4273b4079 api[1060]: at IncomingMessage.onEnd (/usr/src/app/node_modules/aws-sdk/lib/event_listeners.js:313:13)
Nov 19 00:04:40 46b4273b4079 api[1060]: at IncomingMessage.emit (events.js:327:22)
Nov 19 00:04:40 46b4273b4079 api[1060]: at IncomingMessage.EventEmitter.emit (domain.js:467:12)
Nov 19 00:04:40 46b4273b4079 api[1060]: at endReadableNT (internal/streams/readable.js:1327:12)
Nov 19 00:04:40 46b4273b4079 api[1060]: at processTicksAndRejections (internal/process/task_queues.js:80:21)
Nov 19 00:04:46 46b4273b4079 api[1060]: 2021-11-19T00:04:46.506Z 172.18.0.8 s/vpn PATCH /resin/service_instance(14) 200 128.004ms -
Nov 19 00:04:56 46b4273b4079 api[1060]: 2021-11-19T00:04:56.679Z 172.18.0.8 s/vpn PATCH /resin/service_instance(14) 200 145.410ms -
Nov 19 00:05:00 46b4273b4079 api[1060]: [Scheduler] Running job: contractSync
Nov 19 00:05:00 46b4273b4079 api[1060]: [Scheduler] Lock already in place for job: contractSync.
Nov 19 00:05:04 46b4273b4079 api[1060]: [Scheduler] Finished job: contractSync, next run at Fri Nov 19 2021 00:10:00 GMT+0000
Nov 19 00:05:06 46b4273b4079 api[1060]: 2021-11-19T00:05:06.846Z 172.18.0.8 s/vpn PATCH /resin/service_instance(14) 200 143.000ms -
Nov 19 00:05:17 46b4273b4079 api[1060]: 2021-11-19T00:05:17.081Z 172.18.0.8 s/vpn PATCH /resin/service_instance(14) 200 206.003ms -
Nov 19 00:05:27 46b4273b4079 api[1060]: 2021-11-19T00:05:27.167Z 172.18.0.8 s/vpn PATCH /resin/service_instance(14) 200 67.488ms -
Nov 19 00:05:37 46b4273b4079 api[1060]: 2021-11-19T00:05:37.372Z 172.18.0.8 s/vpn PATCH /resin/service_instance(14) 200 174.986ms -
When I try to ping the front end I get a 503
root@ns508681:~# curl -v http://127.0.0.1:81/ping -k
  • Trying 127.0.0.1…
  • TCP_NODELAY set
  • Connected to 127.0.0.1 (127.0.0.1) port 81 (#0)
GET /ping HTTP/1.1
Host: 127.0.0.1:81
User-Agent: curl/7.58.0
Accept: /
  • HTTP 1.0, assume close after body
    < HTTP/1.0 503 Service Unavailable
    < Cache-Control: no-cache
    < Connection: close
    < Content-Type: text/html
No server is available to handle this request. * Closing connection 0
I may have been just been having issues added nginx in front of HA proxy to have a trusted certificate available.
