Hi everyone,
For reasons beyond our control, we have use-cases where we must perform an offline update (no internet on source or target device) without access to the USB port, but rather through a local Wi-Fi network connection.
Background Info:
Using an IoT Gateway 8 with a balena-cloud-TestFleet-iot-gate-imx8-6.5.34+rev7-v17.0.3.img development image. The device has local mode enabled.
What I’ve Tried:
- Balena Deploy : Doesn’t work without internet as it requires a login.
- Balena Push : I receive the error below even though I have the image locally.
- Balena SSH : This would in principal allow me to pull a compressed archive that has all my images, load them with Balena, and then run the containers, but this involves many manual steps and I don’t know if the containers would just get wiped afterwards.
Balena Push Error:
PS C:\Users\serveradmin\Downloads\balena> balena push 192.168.137.104
[Info] Starting build on device 192.168.137.104
[Info] Converting line endings CRLF -> LF for file: C:\Users\serveradmin\Downloads\balena\docker-compose.yml
Some services failed to build:
nginx: (HTTP code 404) unexpected - manifest for nginx:4.4.0 not found: manifest unknown: manifest unknown
cat docker-compose.yml
version: "2.4"
services:
nginx:
container_name: nginx
hostname: nginx
image: nginx:4.4.0
network_mode: host
restart: always
PS C:\Users\serveradmin\Downloads\balena> docker images
REPOSITORY TAG IMAGE ID CREATED SIZE
nginx 4.4.0 fb76f0a364f9 7 hours ago 282MB
Is there a better/established way to do this?
