NVIDIA Driver Crashes on BalenaOS
Hardware:
  • Motherboard: MSI PRO B860M-A WIFI (MS-7E42)
  • GPU: NVIDIA RTX 5080
  • BalenaOS: 6.5 (observed on different versions)
Problem:
System reboots when running modprobe nvidia during driver loading. No kernel logs generated - just clean reboot. Driver compilation succeeds, crash only happens during module load.
Tested on multiple nvidia driver versions 550, 560, 570-open, 575-open, 580
Issue appears BalenaOS-specific. Same hardware works perfectly with Ubuntu 24.04 + NVIDIA drivers
I wonder if anyone else experienced the same issue?
Hi @alexluuniro just bringing here the conclusion from our paid support, please feel free to add any other details you think important.
When I build the open driver without dkms, it loads fine and even works. The only problem is with the gsp_ga10x.bin firmware which either has to be in the host OS, or you have to set firmware search path inside the container, but since your other GPU works fine, it’s clearly possible to make it work.
For reference I’ve used the following container to build them the modules:
FROM debian:13
WORKDIR /usr/src
ENV DEBIAN_FRONTEND noninteractive
# Set some variables to download the proper header modules
ENV VERSION="6.5.44%2Brev2"
ENV BALENA_MACHINE_NAME="generic-amd64"
# Set variables for the Yocto version of the OS
ENV YOCTO_VERSION=6.12.36
ENV YOCTO_KERNEL=${YOCTO_VERSION}-yocto-standard
# Set variables to download proper NVIDIA driver
ENV NVIDIA_DRIVER_VERSION=575.57.08
ENV NVIDIA_DRIVER=NVIDIA-Linux-x86_64-${NVIDIA_DRIVER_VERSION}
# Install some prereqs
RUN apt -y update && apt -y install curl git wget unzip build-essential libelf-dev bc libssl-dev bison flex libglvnd-dev dbus kmod initramfs-tools
WORKDIR /usr/src/kernel_source
# Causes a pipeline to produce a failure return code if any command errors.
# Normally, pipelines only return a failure if the last command errors.
SHELL ["/bin/bash", "-o", "pipefail", "-c"]
# Download the kernel source then prepare kernel source to build a module.
RUN \
    curl -fsSL "https://files.balena-cloud.com/images/${BALENA_MACHINE_NAME}/${VERSION}/kernel_modules_headers.tar.gz" \
        | tar xz --strip-components=2 && \
    make -C build modules_prepare -j"$(nproc)"
WORKDIR /usr/src/nvidia
# Download and compile NVIDIA driver
RUN \
    curl -fsSL -O https://us.download.nvidia.com/XFree86/Linux-x86_64/$NVIDIA_DRIVER_VERSION/$NVIDIA_DRIVER.run && \
    chmod +x ./${NVIDIA_DRIVER}.run && \
    ./${NVIDIA_DRIVER}.run --extract-only && \
    # Install userspace portion, needed if container will also have CUDA etc...
    # Not needed if just building kernel module.
    # Do include in any application container.
    ./${NVIDIA_DRIVER}/nvidia-installer \
    --ui=none \
    --no-questions \
    --no-drm \
    --no-x-check \
    --no-systemd \
    --no-kernel-module \
    --no-distro-scripts \
    --install-compat32-libs \
    --no-nouveau-check \
    --no-rpms \
    --no-backup \
    --no-abi-note \
    --no-check-for-alternate-installs \
    --no-libglx-indirect \
    --install-libglvnd \
    --x-prefix=/tmp/null \
    --x-module-path=/tmp/null \
    --x-library-path=/tmp/null \
    --x-sysconfig-path=/tmp/null \
    --kernel-name=${YOCTO_KERNEL} \
    --skip-depmod \
    --expert && \
    make -C ${NVIDIA_DRIVER}/kernel-open KERNEL_MODLIB=/usr/src/kernel_source IGNORE_CC_MISMATCH=1 modules
WORKDIR /nvidia/driver
RUN find /usr/src/nvidia/${NVIDIA_DRIVER}/kernel-open -name "*.ko" -exec mv {} . \;
WORKDIR /usr/src/app
COPY *.sh ./
ENTRYPOINT ["/bin/bash", "/usr/src/app/entry.sh"]
