The latest version of WiFi Connect doesn’t have an archive file that can work for Raspberry Pi devices with ARM v6 CPU (i.e., the one with “rpi” in its filename, for instance, wifi-connect-v4.11.1-linux-rpi.zip. Is this latest WiFi Connect version not supported on Raspberry Pi 1 (even though a Wi-Fi dongle can be used)?
Hello, where are you looking for the archive files? We do have a version on balenaHub for the Raspberry Pi compatible with armv6: balenaHub - IoT embedded device apps, edge computing resources, and developer tools
Hi @nicomiguelino,
We just wanted to check back in to see if you saw Alan’s message and could share the location of the archive files you were looking through? Any updates are appreciated!
Hello @alanb128 & @the-real-kenna. Apologies for the late response. I’ve checked Alan’s message. I prefer to use the latest version for Pi devices with an armv6 processor.
I haven’t tried to use that version for RPi 1 though. I’ll get back to you once I have the results. Thank you so much!
