Hi!
I have a raspberry Pi with a Quectel EG95 hat using latest BalenaOS 2.47.0+rev1 (production mode) that shows up fine in ModemManager:
mmcli -L
/org/freedesktop/ModemManager1/Modem/0 [Quectel] EG95
Then when I try to connect to the internet the pppd process fails at status 3 / phase 'serial connection, and gives the error:
" ppp-manager: pppd timed out or didn't initialize our dbus module". NM then disconnects the device.
If I run my own pppd call script it successfully connects to the internet, however I want it to be manageable by the Network manager.
As you see in the logs below, I have tried to play around with different ppp options (or none) in /etc/ppp/options without any different result.
Detailed debug logs from both MM and NM below:
ModemManager:
May 12 13:15:58 85305ec ModemManager[673]: Modem /org/freedesktop/ModemManager1/Modem/0: signal quality updated (80)
May 12 13:15:58 85305ec ModemManager[673]: Periodic signal quality and access technology checks scheduled
May 12 13:15:58 85305ec ModemManager[673]: (ttyS0) device open count is 1 (close)
May 12 13:16:27 85305ec ModemManager[673]: User request to connect modem
May 12 13:16:27 85305ec ModemManager[673]: Simple connect started...
May 12 13:16:27 85305ec ModemManager[673]: PIN: unspecified
May 12 13:16:27 85305ec ModemManager[673]: Operator ID: unspecified
May 12 13:16:27 85305ec ModemManager[673]: Allowed roaming: yes
May 12 13:16:27 85305ec ModemManager[673]: APN: online.telia.se
May 12 13:16:27 85305ec ModemManager[673]: IP family: ipv4v6
May 12 13:16:27 85305ec ModemManager[673]: Allowed authentication: none, pap, chap, mschap, mschapv2, eap
May 12 13:16:27 85305ec ModemManager[673]: User: unspecified
May 12 13:16:27 85305ec ModemManager[673]: Password: unspecified
May 12 13:16:27 85305ec ModemManager[673]: Simple connect state (4/8): Wait to get fully enabled
May 12 13:16:27 85305ec ModemManager[673]: Simple connect state (5/8): Register
May 12 13:16:27 85305ec ModemManager[673]: Already registered in network '24001', automatic registration not launched...
May 12 13:16:27 85305ec ModemManager[673]: Simple connect state (6/8): Bearer
May 12 13:16:27 85305ec ModemManager[673]: Creating new bearer...
May 12 13:16:27 85305ec ModemManager[673]: Creating Broadband bearer in broadband modem
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0) device open count is 2 (open)
May 12 13:16:27 85305ec ModemManager[673]: Simple connect state (7/8): Connect
May 12 13:16:27 85305ec ModemManager[673]: Connecting bearer '/org/freedesktop/ModemManager1/Bearer/0'
May 12 13:16:27 85305ec ModemManager[673]: Modem /org/freedesktop/ModemManager1/Modem/0: state changed (registered -> connecting)
May 12 13:16:27 85305ec ModemManager[673]: Launching 3GPP connection attempt with APN 'online.telia.se'
May 12 13:16:27 85305ec ModemManager[673]: Checking context definition format...
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0) device open count is 3 (open)
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0) device open count is 2 (close)
May 12 13:16:27 85305ec ModemManager[673]: Unhandled PDP type in CGDCONT=? reply: 'PPP'
May 12 13:16:27 85305ec ModemManager[673]: Checking currently defined contexts...
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0): --> 'AT+CGDCONT?<CR>'
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0): <-- '<CR>'
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0): <-- '<LF>+C'
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0): <-- 'G'
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0): <-- 'D'
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0): <-- 'C'
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0): <-- 'ON'
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0): <-- 'T'
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0): <-- ':'
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0): <-- ' '
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0): <-- '1'
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0): <-- ',"'
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0): <-- 'I'
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0): <-- 'P'
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0): <-- '",'
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0): <-- '"'
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0): <-- 'o'
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0): <-- 'nl'
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0): <-- 'i'
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0): <-- 'ne'
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0): <-- '.'
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0): <-- 'tel'
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0): <-- 'ia'
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0): <-- 's'
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0): <-- 'e"'
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0): <-- ','
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0): <-- '"0'
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0): <-- '0'
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0): <-- '.0'
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0): <-- '0"'
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0): <-- '0,'
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0): <-- '<CR><LF>'
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0): <-- '+'
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0): <-- 'CG'
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0): <-- 'CO'
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0): <-- 'N'
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0): <-- 'T:'
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0): <-- '2,'
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0): <-- 'IP'
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0): <-- 'V'
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0): <-- '4V'
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0): <-- '6"'
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0): <-- '"o'
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0): <-- '.t'
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0): <-- 'e'
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0): <-- 'li'
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0): <-- 'a.'
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0): <-- '0.'
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0): <-- '0.0'
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0): <-- '.0.'
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0): <-- '0",0'
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0): <-- ',0,0'
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0): <-- ',0<CR><LF>'
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0): <-- '<CR><LF>OK'
May 12 13:16:27 85305ec ModemManager[673]: Found '2' PDP contexts
May 12 13:16:27 85305ec ModemManager[673]: PDP context [cid=1] [type='ipv4'] [apn='online.telia.se']
May 12 13:16:27 85305ec ModemManager[673]: PDP context [cid=2] [type='ipv4v6'] [apn='online.telia.se']
May 12 13:16:27 85305ec ModemManager[673]: Looking for best CID matching APN 'online.telia.se' and PDP type 'ipv4v6'...
May 12 13:16:27 85305ec ModemManager[673]: Found exact context at CID 2
May 12 13:16:27 85305ec ModemManager[673]: Connection through a plain serial AT port (ttyS0)
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0) device open count is 4 (open)
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0) device open count is 3 (close)
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0): --> 'ATD*99***2#<CR>'
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0): <-- '<LF>CON'
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0): <-- 'NEC'
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0): <-- 'T 1'
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0): <-- '500'
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0): <-- '000'
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0): <-- '00<CR>'
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0): <-- '<LF>'
May 12 13:16:27 85305ec ModemManager[673]: (ttyS0): port now connected
May 12 13:16:27 85305ec ModemManager[673]: Connected bearer '/org/freedesktop/ModemManager1/Bearer/0'
May 12 13:16:27 85305ec ModemManager[673]: PPP is required for connection, will ignore disconnection reports
May 12 13:16:27 85305ec ModemManager[673]: Modem /org/freedesktop/ModemManager1/Modem/0: state changed (connecting -> connected)
May 12 13:16:27 85305ec ModemManager[673]: Simple connect state (8/8): All done
May 12 13:16:28 85305ec ModemManager[673]: loading signal quality...
May 12 13:16:28 85305ec ModemManager[673]: Couldn't refresh signal quality: 'No AT port available to run command'
May 12 13:16:28 85305ec ModemManager[673]: Periodic signal quality and access technology checks scheduled
May 12 13:16:57 85305ec ModemManager[673]: Connection monitoring is unsupported by the device
May 12 13:16:58 85305ec ModemManager[673]: Signal quality value not updated in 60s, marking as not being recent
May 12 13:16:58 85305ec ModemManager[673]: loading signal quality...
May 12 13:16:58 85305ec ModemManager[673]: Couldn't refresh signal quality: 'No AT port available to run command'
May 12 13:16:58 85305ec ModemManager[673]: Periodic signal quality and access technology checks scheduled
NetworkManager:
May 12 13:16:27 85305ec NetworkManager[749]: <info> [1589289387.7365] device (ttyS0): Activation: starting connection 'cellular' (57929095-bcf5-40b1-9690-3bf54b4dc6c4)
May 12 13:16:27 85305ec NetworkManager[749]: <debug> [1589289387.7368] device[0xb78430] (ttyS0): activation-stage: schedule activate_stage1_device_prepare,v4 (id 976)
May 12 13:16:27 85305ec NetworkManager[749]: <debug> [1589289387.7369] manager: ActivatingConnection now (none)
May 12 13:16:27 85305ec NetworkManager[749]: <debug> [1589289387.7386] create NMAuditManager singleton (793d6384c795a1c9)
May 12 13:16:27 85305ec NetworkManager[749]: <info> [1589289387.7388] audit: op="connection-activate" uuid="57929095-bcf5-40b1-9690-3bf54b4dc6c4" name="cellular" pid=1827 uid=0 result="success"
May 12 13:16:27 85305ec NetworkManager[749]: <debug> [1589289387.7389] device[0xb78430] (ttyS0): activation-stage: invoke activate_stage1_device_prepare,v4 (id 976)
May 12 13:16:27 85305ec NetworkManager[749]: <info> [1589289387.7397] device (ttyS0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
May 12 13:16:27 85305ec NetworkManager[749]: <debug> [1589289387.7429] active-connection[0xa89a00]: set state activating (was unknown)
May 12 13:16:27 85305ec NetworkManager[749]: <debug> [1589289387.7444] active-connection[0xa89a00]: check-master-ready: not signalling (state activating, no master)
May 12 13:16:27 85305ec NetworkManager[749]: <debug> [1589289387.7450] modem-broadband[ttyS0]: launching connection with ip type 'ipv4v6' (try 1)
May 12 13:16:27 85305ec NetworkManager[749]: <debug> [1589289387.7457] device[0xb78430] (ttyS0): activation-stage: complete activate_stage1_device_prepare,v4 (id 976)
May 12 13:16:27 85305ec NetworkManager[749]: <info> [1589289387.7514] modem["ttyS0"]: modem state changed, 'registered' --> 'connecting' (reason: user-requested)
May 12 13:16:27 85305ec NetworkManager[749]: <debug> [1589289387.7516] device[0xb78430] (ttyS0): add_pending_action (2): 'recheck-available'
May 12 13:16:27 85305ec NetworkManager[749]: <debug> [1589289387.7517] device[0xb78430] (ttyS0): remove_pending_action (1): 'recheck-available'
May 12 13:16:27 85305ec NetworkManager[749]: <info> [1589289387.8062] modem["ttyS0"]: modem state changed, 'connecting' --> 'connected' (reason: user-requested)
May 12 13:16:27 85305ec NetworkManager[749]: <debug> [1589289387.8064] device[0xb78430] (ttyS0): add_pending_action (2): 'recheck-available'
May 12 13:16:27 85305ec NetworkManager[749]: <debug> [1589289387.8066] device[0xb78430] (ttyS0): remove_pending_action (1): 'recheck-available'
May 12 13:16:27 85305ec NetworkManager[749]: <debug> [1589289387.8173] device[0xb78430] (ttyS0): activation-stage: schedule activate_stage2_device_config,v4 (id 992)
May 12 13:16:27 85305ec NetworkManager[749]: <debug> [1589289387.8183] device[0xb78430] (ttyS0): activation-stage: invoke activate_stage2_device_config,v4 (id 992)
May 12 13:16:27 85305ec NetworkManager[749]: <info> [1589289387.8186] device (ttyS0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
May 12 13:16:27 85305ec NetworkManager[749]: <debug> [1589289387.8230] rules-manager: sync
May 12 13:16:27 85305ec NetworkManager[749]: <debug> [1589289387.8232] device[0xb78430] (ttyS0): bringing up device 0
May 12 13:16:27 85305ec NetworkManager[749]: <debug> [1589289387.8233] firewall: [0x940fb8,change*:"ttyS0"]: firewall zone change ttyS0:default (not running, simulate success)
May 12 13:16:27 85305ec NetworkManager[749]: <debug> [1589289387.8233] device[0xb78430] (ttyS0): activation-stage: complete activate_stage2_device_config,v4 (id 992)
May 12 13:16:27 85305ec NetworkManager[749]: <debug> [1589289387.8234] firewall: [0x940fb8,change*:"ttyS0"]: complete: fake success
May 12 13:16:27 85305ec NetworkManager[749]: <debug> [1589289387.8235] device[0xb78430] (ttyS0): activation-stage: schedule activate_stage3_ip_config_start,v4 (id 994)
May 12 13:16:27 85305ec NetworkManager[749]: <debug> [1589289387.8235] device[0xb78430] (ttyS0): activation-stage: invoke activate_stage3_ip_config_start,v4 (id 994)
May 12 13:16:27 85305ec NetworkManager[749]: <debug> [1589289387.8236] active-connection[0xa89a00]: set state-flags layer2-ready (was none)
May 12 13:16:27 85305ec NetworkManager[749]: <info> [1589289387.8241] device (ttyS0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
May 12 13:16:27 85305ec NetworkManager[749]: <debug> [1589289387.8249] modem["ttyS0"]: ip4_config_start
May 12 13:16:27 85305ec NetworkManager[749]: <info> [1589289387.8251] modem["ttyS0"]: using modem-specified IP timeout: 20 seconds
May 12 13:16:27 85305ec NetworkManager[749]: <info> [1589289387.8307] loaded PPP plugin /usr/lib/NetworkManager/1.20.2/libnm-ppp-plugin.so
May 12 13:16:27 85305ec NetworkManager[749]: <info> [1589289387.8315] ppp-manager: starting PPP connection
May 12 13:16:27 85305ec NetworkManager[749]: <debug> [1589289387.8316] ppp-manager: command line: /usr/sbin/pppd nodetach lock nodefaultroute ipv6 , debug ttyS0 noipdefault 115200 noauth nobsdcomp novj nodeflate usepeerdns lcp-echo-failure 0 lcp-echo-interval 0 idle 0 ipparam /org/freedesktop/NetworkManager/PPP/1 plugin /usr/lib/pppd/2.4.5/nm-pppd-plugin.so
May 12 13:16:27 85305ec NetworkManager[749]: <info> [1589289387.8442] ppp-manager: pppd started with pid 1831
May 12 13:16:27 85305ec NetworkManager[749]: <debug> [1589289387.8446] device[0xb78430] (ttyS0): activation-stage: complete activate_stage3_ip_config_start,v4 (id 994)
May 12 13:16:27 85305ec NetworkManager[749]: Plugin /usr/lib/pppd/2.4.5/nm-pppd-plugin.so loaded.
May 12 13:16:27 85305ec NetworkManager[749]: nm-pppd-plugin-Message: 13:16:27.894: nm-ppp-plugin: initializing
May 12 13:16:27 85305ec NetworkManager[749]: pppd options in effect:
May 12 13:16:27 85305ec NetworkManager[749]: debug debug # (from command line)
May 12 13:16:27 85305ec NetworkManager[749]: nodetach # (from command line)
May 12 13:16:27 85305ec NetworkManager[749]: idle 0 # (from command line)
May 12 13:16:27 85305ec NetworkManager[749]: dump # (from /etc/ppp/options)
May 12 13:16:27 85305ec NetworkManager[749]: plugin /usr/lib/pppd/2.4.5/nm-pppd-plugin.so # (from command line)
May 12 13:16:27 85305ec NetworkManager[749]: noauth # (from command line)
May 12 13:16:27 85305ec NetworkManager[749]: user internet # (from /etc/ppp/options)
May 12 13:16:27 85305ec NetworkManager[749]: remotename 3gppp # (from /etc/ppp/options)
May 12 13:16:27 85305ec NetworkManager[749]: /dev/ttyS0 # (from command line)
May 12 13:16:27 85305ec NetworkManager[749]: 115200 # (from command line)
May 12 13:16:27 85305ec NetworkManager[749]: lock # (from command line)
May 12 13:16:27 85305ec NetworkManager[749]: nocrtscts # (from /etc/ppp/options)
May 12 13:16:27 85305ec NetworkManager[749]: modem # (from /etc/ppp/options)
May 12 13:16:27 85305ec NetworkManager[749]: asyncmap 0 # (from /etc/ppp/options)
May 12 13:16:27 85305ec NetworkManager[749]: lcp-echo-failure 0 # (from command line)
May 12 13:16:27 85305ec NetworkManager[749]: lcp-echo-interval 0 # (from command line)
May 12 13:16:27 85305ec NetworkManager[749]: hide-password # (from /etc/ppp/options)
May 12 13:16:27 85305ec NetworkManager[749]: novj # (from command line)
May 12 13:16:27 85305ec NetworkManager[749]: novjccomp # (from /etc/ppp/options)
May 12 13:16:27 85305ec NetworkManager[749]: ipcp-accept-local # (from /etc/ppp/options)
May 12 13:16:27 85305ec NetworkManager[749]: ipcp-accept-remote # (from /etc/ppp/options)
May 12 13:16:27 85305ec NetworkManager[749]: ipparam /org/freedesktop/NetworkManager/PPP/1 # (from command line)
May 12 13:16:27 85305ec NetworkManager[749]: noipdefault # (from command line)
May 12 13:16:27 85305ec NetworkManager[749]: ipcp-max-failure 30 # (from /etc/ppp/options)
May 12 13:16:27 85305ec NetworkManager[749]: # (from /etc/ppp/options)
May 12 13:16:27 85305ec NetworkManager[749]: nodefaultroute # (from command line)
May 12 13:16:27 85305ec NetworkManager[749]: usepeerdns # (from command line)
May 12 13:16:27 85305ec NetworkManager[749]: ipv6 , # (from command line)
May 12 13:16:27 85305ec NetworkManager[749]: noccp # (from /etc/ppp/options)
May 12 13:16:27 85305ec NetworkManager[749]: nobsdcomp # (from command line)
May 12 13:16:27 85305ec NetworkManager[749]: nodeflate # (from command line)
May 12 13:16:27 85305ec NetworkManager[749]: noipx # (from /etc/ppp/options)
May 12 13:16:27 85305ec NetworkManager[749]: nm-pppd-plugin-Message: 13:16:27.919: nm-ppp-plugin: status 3 / phase 'serial connection'
May 12 13:16:29 85305ec NetworkManager[749]: <debug> [1589289389.7081] connectivity: (ttyS0,IPv4,43) start fake request (fake result)
May 12 13:16:29 85305ec NetworkManager[749]: <debug> [1589289389.7083] connectivity: (ttyS0,IPv6,44) start fake request (fake result)
May 12 13:16:29 85305ec NetworkManager[749]: <debug> [1589289389.7085] connectivity: (ttyS0,IPv4,43) check completed: FAKE; fake result
May 12 13:16:29 85305ec NetworkManager[749]: <debug> [1589289389.7086] connectivity: (ttyS0,IPv6,44) check completed: FAKE; fake result
May 12 13:16:47 85305ec NetworkManager[749]: <warn> [1589289407.9561] ppp-manager: pppd timed out or didn't initialize our dbus module
May 12 13:16:47 85305ec NetworkManager[749]: <debug> [1589289407.9569] kill child process 'pppd' (1831): wait for process to terminate after sending SIGTERM (15) (send SIGKILL in 1500 milliseconds)...
May 12 13:16:47 85305ec NetworkManager[749]: <debug> [1589289407.9571] device[0xb78430] (ttyS0): activation-stage: schedule activate_stage4_ip_config_timeout_4,v4 (id 1006)
May 12 13:16:47 85305ec NetworkManager[749]: <debug> [1589289407.9573] device[0xb78430] (ttyS0): activation-stage: invoke activate_stage4_ip_config_timeout_4,v4 (id 1006)
May 12 13:16:47 85305ec NetworkManager[749]: <debug> [1589289407.9575] device[0xb78430] (ttyS0): activation-stage: complete activate_stage4_ip_config_timeout_4,v4 (id 1006)
May 12 13:16:48 85305ec NetworkManager[749]: nm-pppd-plugin-Message: 13:16:48.957: nm-ppp-plugin: status 1 / phase 'dead'
May 12 13:16:48 85305ec NetworkManager[749]: nm-pppd-plugin-Message: 13:16:48.958: nm-ppp-plugin: cleaning up
May 12 13:16:48 85305ec NetworkManager[749]: <debug> [1589289408.9617] kill child process 'pppd' (1831): terminated normally with status 9 (1004742 usec elapsed)
May 12 13:17:33 85305ec NetworkManager[749]: <debug> [1589289453.7124] connectivity: (ttyS0,IPv4,45) start fake request (fake result)
May 12 13:17:33 85305ec NetworkManager[749]: <debug> [1589289453.7126] connectivity: (ttyS0,IPv6,46) start fake request (fake result)
May 12 13:17:33 85305ec NetworkManager[749]: <debug> [1589289453.7128] connectivity: (ttyS0,IPv4,45) check completed: FAKE; fake result
May 12 13:17:33 85305ec NetworkManager[749]: <debug> [1589289453.7129] connectivity: (ttyS0,IPv6,46) check completed: FAKE; fake result
May 12 13:17:58 85305ec NetworkManager[749]: <debug> [1589289478.0076] agent-manager: req[0xbd6928, :1.67/nmcli-connect/0]: agent unregistered or disappeared
Thanks in advance!
