ERROR: OE-core's config sanity checker detected a potential misconfiguration.
Either fix the cause of this error or at your own risk disable the checker (see sanity.conf).
Following is the list of potential problems / advisories:
Fetcher failure for URL: 'https://www.example.com/'. URL https://www.example.com/ doesn't work.
Please ensure your host's network is configured correctly,
or set BB_NO_NETWORK = "1" to disable network access if
all required sources are on local disk.
# The CONNECTIVITY_CHECK_URI's are used to test whether we can succesfully
# fetch from the network (and warn you if not). To disable the test set
# the variable to be empty.
# Git example url: git://git.yoctoproject.org/yocto-firewall-test;protocol=git;rev=master
CONNECTIVITY_CHECK_URIS ?= "https://www.google.com/"
… but now I am getting follow error:
[000000001][LOG]This might take a while ...
ERROR: /workdir/balena-intel/build/../layers/meta-balena/meta-balena-common/recipes-containers/docker-disk/docker-disk.bb: docker-disk: Docker needs to run on your host and current user must be able to use it.
ERROR: Failed to parse recipe: /workdir/balena-intel/build/../layers/meta-balena/meta-balena-common/recipes-containers/docker-disk/docker-disk.bb
Summary: There were 2 ERROR messages shown, returning a non-zero exit code
I have no clue how to fix this. I have added user pokyuser to docker group but this didn’t fix it:
pokyuser@ae30fa5181cf:/workdir/balena-intel$ groups pokyuser
pokyuser : pokyuser sudo docker
So, I have no clue how to progress and I am certainly not sure that I am following the right track for building a balena OS as I have encountered already several problems.
Hi @janvda - you have probably already done this but make sure you have logged out and back in again after running " sudo usermod -aG docker $your_user". If it is not that, then I would debug your Docker setup first as your current user. Does docker run hello-world work as expected?
Not sure how I can logout and login.
To make this clear : see the below commands I have executed in a terminal session on my macbook.
docker run --rm -it -v myvolume:/workdir crops/poky --workdir=/workdir
pokyuser@bc7bf4d63025:/workdir$ logout
bash: logout: not login shell: use `exit'
Note also that executing command docker run hello-world in same terminal session doesn’t work for me. I am getting:
pokyuser@bc7bf4d63025:/workdir$ docker run hello-world
docker: Cannot connect to the Docker daemon at unix:///var/run/docker.sock. Is the docker daemon running?.
See 'docker run --help'.
It is all very frustrating. I started from a docker container crops/poky which I would expect that it has everything needed for a build as that is the sole purpose of that container and still I am getting one issue after the other. So I am thinking that I should not use crops/poky container. What is actually the recommended way of building a balena image on a macbook ?
Sorry, I missed you were running this in a Docker container. I’ve never used this but I did find this from one of my colleagues https://github.com/alexgg/docker-balena that might make a better starting point? The balena build does have extra requirements over a normal Yocto build, namely jq, Docker and Node.js.
So I have followed the instructions of the “Use” section of the readme and when executing the command:
docker run --rm -it --privileged -v /Users/jan/Documents/15_iot/build_os/nuc/balena-intel:/home/build aggurio/docker-balena
I am getting error:
[000000003][LOG]This might take a while ...
The TMPDIR (/home/build/build/tmp) can't be on a case-insensitive file system.
Summary: There was 1 ERROR message shown, returning a non-zero exit code.
I guess you could also just run the commands from the Docker container directly to avoid the bind mount? i.e. docker run --rm -it --privileged docker-balena:warrior bash and then build as per the instructions here: https://www.balena.io/os/docs/custom-build/.
ERROR: linux-libc-headers-5.0-r0 do_unpack: Function failed: base_do_unpack
and warning:
WARNING : libtirpc-native-1.0.3-r0 do_fetch: Failed to fetch URL https://downloads.sourceforge.net/libtirpc/libtirpc-1.0.3.tar.bz2, attempting MIRRORS if available
Here below the full log:
build@5277e455b22f:~/balena-intel$ ./balena-yocto-scripts/build/barys -m genericx86-64
Building JSON manifest...
audited 3 packages in 1.022s
found 0 vulnerabilities
...Done
_ _ ___ ____
| |__ __ _| | ___ _ __ __ _ / _ \/ ___|
| '_ \ / _` | |/ _ \ '_ \ / _` | | | \___ \
| |_) | (_| | | __/ | | | (_| | |_| |___) |
|_.__/ \__,_|_|\___|_| |_|\__,_|\___/|____/
Resin specific images available:
resin-image-flasher
Intel NUC : $ MACHINE=genericx86-64 bitbake resin-image-flasher
Microsoft Surface Go (EXPERIMENTAL) : $ MACHINE=surface-go bitbake resin-image-flasher
Microsoft Surface 6 (EXPERIMENTAL) : $ MACHINE=surface-pro-6 bitbake resin-image-flasher
[000000003][LOG]BalenaOS build initialized in directory: build.
[000000003][LOG]Run build for genericx86-64: MACHINE=genericx86-64 bitbake resin-image-flasher
Loading cache: 100% |##############################################################################################################| Time: 0:00:00
Loaded 3338 entries from dependency cache.
Parsing recipes: 100% |############################################################################################################| Time: 0:00:02
Parsing of 2249 .bb files complete (2248 cached, 1 parsed). 3338 targets, 287 skipped, 0 masked, 0 errors.
NOTE: Resolving any missing task queue dependencies
Build Configuration:
BB_VERSION = "1.42.0"
BUILD_SYS = "x86_64-linux"
NATIVELSBSTRING = "debian-9"
TARGET_SYS = "x86_64-poky-linux"
MACHINE = "genericx86-64"
DISTRO = "balena-os"
DISTRO_VERSION = "2.46.0"
TUNE_FEATURES = "m64 core2"
TARGET_FPU = ""
meta
meta-poky
meta-yocto-bsp = "HEAD:b021992106c6b5ba02b825afa7dcc422b135b59b"
meta-oe
meta-filesystems
meta-networking
meta-python = "HEAD:6fa72d587aab8e9d56d67a2552eb9cfbe25c86d2"
meta-balena-common
meta-balena-warrior = "HEAD:53e2100d2c1074d23c5d117180bd488899c8a2e9"
meta-balena-genericx86 = "master:f5f16b88931f0b4f978ae9e0fb5afb9ce948668f"
meta-rust = "HEAD:84710b341be53cc2af13ecc8ae87773cf84687bf"
NOTE: Fetching uninative binary shim from http://downloads.yoctoproject.org/releases/uninative/2.7/x86_64-nativesdk-libc.tar.xz;sha256sum=9498d8bba047499999a7310ac2576d0796461184965351a56f6d32c888a1f216
Initialising tasks: 100% |#########################################################################################################| Time: 0:00:04
Sstate summary: Wanted 1487 Found 0 Missed 1487 Current 0 (0% match, 0% complete)
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
WARNING: libtirpc-native-1.0.3-r0 do_fetch: Failed to fetch URL https://downloads.sourceforge.net/libtirpc/libtirpc-1.0.3.tar.bz2, attempting MIRRORS if available
ERROR: linux-libc-headers-5.0-r0 do_unpack: Unpack failure for URL: 'https://cdn.kernel.org/pub/linux/kernel/v5.x/linux-5.0.tar.xz'. Unpack command PATH="/home/build/balena-intel/build/tmp/sysroots-uninative/x86_64-linux/usr/bin:/home/build/balena-intel/layers/poky/scripts:/home/build/balena-intel/build/tmp/work/core2-64-poky-linux/linux-libc-headers/5.0-r0/recipe-sysroot-native/usr/bin/x86_64-poky-linux:/home/build/balena-intel/build/tmp/work/core2-64-poky-linux/linux-libc-headers/5.0-r0/recipe-sysroot/usr/bin/crossscripts:/home/build/balena-intel/build/tmp/work/core2-64-poky-linux/linux-libc-headers/5.0-r0/recipe-sysroot-native/usr/sbin:/home/build/balena-intel/build/tmp/work/core2-64-poky-linux/linux-libc-headers/5.0-r0/recipe-sysroot-native/usr/bin:/home/build/balena-intel/build/tmp/work/core2-64-poky-linux/linux-libc-headers/5.0-r0/recipe-sysroot-native/sbin:/home/build/balena-intel/build/tmp/work/core2-64-poky-linux/linux-libc-headers/5.0-r0/recipe-sysroot-native/bin:/home/build/balena-intel/layers/poky/bitbake/bin:/home/build/balena-intel/build/tmp/hosttools" xz -dc /home/build/balena-intel/build/downloads/linux-5.0.tar.xz | tar x --no-same-owner -f - failed with return value 2
ERROR: Logfile of failure stored in: /home/build/balena-intel/build/tmp/work/core2-64-poky-linux/linux-libc-headers/5.0-r0/temp/log.do_unpack.92038
ERROR: Task (/home/build/balena-intel/build/../layers/poky/meta/recipes-kernel/linux-libc-headers/linux-libc-headers_5.0.bb:do_unpack) failed with exit code '1'
**NOTE** : Tasks Summary: Attempted 183 tasks of which 0 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There was 1 WARNING message shown.
Summary: There were 3 ERROR messages shown, returning a non-zero exit code.
[000001188][LOG]Build for genericx86-64 failed. Check failed log in build/tmp/log/cooker/genericx86-64 .
[000001188][LOG]If build for genericx86-64 succeeded, final image should have been generated here:
[000001188][LOG] build/tmp/deploy/images/genericx86-64/resin-image-flasher-genericx86-64.resinos-img
[000001189][LOG]Done.
So it has generated an image, but due to the error I am not tempted to try this image out.
I did some googling for the error but couldn’t immediately find a solution for this.
So I am stuck again.
I am still busy trying to build a balena OS with the necessary firmware for my wifi but I am wondering how this could actually help fixing the problem of my NUC going down (after several hours).
Hey, it may help if the issue is due to missing drivers causing issues however I would expect that to be unlikely albeit possible, eg if power management comes into it. I think the suggestion came more from a miscommunication of the issue internally between hanging vs being offline. For the original issue of hanging the only thing that comes to mind is that at least some older Intel SoCs had issues with hanging when transitioning to idle states: https://github.com/balena-os/balena-intel/pull/122 Can you check /proc/cmdline on the device and make sure that intel_idle.max_cstate=1 is set? If not then adding it is definitely the way to go and if it is then trying intel_idle.max_cstate=0 would be a good way to go to see if that fixes the hanging.
Indeed “hanging” would describe this issue better than “going offline/down”.
Thanks for the response. In the mean time I have installed a different linux OS (centos). This way I can exclude it is an hardware issue. So far I had no issues.
