I am trying to run multiple containers on a RPI4 and I am using docker-compose file for the definition of the services. Each service seems to be starting ok but seems to be failing when they try to talk to each other. Following is a sample of the definition of a couple of services, and I use the service hostname to refer to the services. Is that supported? I am also seeing errors like the following when trying to access the services:
msg="Error getting ping: Get http://edgex-core-metadata:48081/api/v1/ping: dial tcp: lookup edgex-core-metadata on 127.0.0.11:53: no such host "
Is anything missing in my docker-compose in order to allow the containers in the same network to communicate?
metadata:
image: edgexfoundry/docker-core-metadata-go-arm64:1.2.0
ports:
- "127.0.0.1:48081:48081"
container_name: edgex-core-metadata
hostname: edgex-core-metadata
networks:
- edgex-network
environment:
<<: *common-variables
Service_Host: edgex-core-metadata
Notifications_Sender: edgex-core-metadata
SecretStore_TokenFile: /tmp/edgex/secrets/edgex-core-metadata/secrets-token.json
volumes:
- tmp-secrets:/tmp/edgex/secrets
depends_on:
- consul
- mongo
- notifications
- vault-worker
data:
image: edgexfoundry/docker-core-data-go-arm64:1.2.0
ports:
- "127.0.0.1:48080:48080"
- "127.0.0.1:5563:5563"
container_name: edgex-core-data
hostname: edgex-core-data
networks:
- edgex-network
environment:
Service_Host: edgex-core-data
SecretStore_TokenFile: /tmp/edgex/secrets/edgex-core-data/secrets-token.json
volumes:
depends_on:
- consul
- mongo
- metadata
- vault-worker
networks:
edgex-network:
driver: "bridge"
Marcelo
