UPDATE: I believe this is expected behaviour with multicontainer – it just doesn’t match my use case.
I’ve been moving devices from one application to another and experiencing some unexpected behaviour. After some digging around, it looks like both our old container and our new container are running simultaneously on the same device after changing applications.
Here’s the log output after I moved from my Nick app to my Nick2 app:
22.03.18 15:11:02 (-0500) DOING THINGS IN Nick FROM COMMIT 95a7fb29fe9c13cf48d18716cd4930c140368149
22.03.18 15:11:05 (-0500) DOING THINGS IN Nick2 FROM COMMIT 95a7fb29fe9c13cf48d18716cd4930c140368149
22.03.18 15:11:05 (-0500) DOING THINGS IN Nick FROM COMMIT 95a7fb29fe9c13cf48d18716cd4930c140368149
22.03.18 15:11:08 (-0500) DOING THINGS IN Nick2 FROM COMMIT 95a7fb29fe9c13cf48d18716cd4930c140368149
22.03.18 15:11:08 (-0500) DOING THINGS IN Nick FROM COMMIT 95a7fb29fe9c13cf48d18716cd4930c140368149
22.03.18 15:11:11 (-0500) DOING THINGS IN Nick2 FROM COMMIT 95a7fb29fe9c13cf48d18716cd4930c140368149
22.03.18 15:11:11 (-0500) DOING THINGS IN Nick FROM COMMIT 95a7fb29fe9c13cf48d18716cd4930c140368149
22.03.18 15:11:14 (-0500) DOING THINGS IN Nick2 FROM COMMIT 95a7fb29fe9c13cf48d18716cd4930c140368149
22.03.18 15:11:14 (-0500) DOING THINGS IN Nick FROM COMMIT 95a7fb29fe9c13cf48d18716cd4930c140368149
22.03.18 15:11:17 (-0500) DOING THINGS IN Nick2 FROM COMMIT 95a7fb29fe9c13cf48d18716cd4930c140368149
22.03.18 15:11:17 (-0500) DOING THINGS IN Nick FROM COMMIT 95a7fb29fe9c13cf48d18716cd4930c140368149
22.03.18 15:11:20 (-0500) DOING THINGS IN Nick2 FROM COMMIT 95a7fb29fe9c13cf48d18716cd4930c140368149
Is this expected behaviour? I’m running Resin OS 2.9.6+rev1 (dev) and Supervisor Version 6.5.9. Do I need to update either to fix this issue?
UPDATE: With @imrehg’s help, I’ve updated to Resin OS 2.12.3+rev1 (dev) and Supervisor 7.1.14 , but still see the same issues.
Here’s the Dockerfile:
// Dockerfile
FROM resin/rpi-raspbian:jessie
# Set environment variables
ENV MAIDBOT_WS="/home/robot" \
LC_ALL=C.UTF-8 \
DEBIAN_FRONTEND=noninteractive
WORKDIR $MAIDBOT_WS
RUN apt-get update && \
apt-get -y install --no-install-recommends --fix-missing procmail && \
apt-get clean && \
rm -rf /var/lib/apt/lists/*
ENTRYPOINT ["entry.sh"]
CMD ["loop_echo_inf"]
And the entry script:
// entry.sh
function loop_echo_inf()
while true; do
echo 'DOING THINGS IN' $RESIN_APP_NAME 'FROM COMMIT' $RESIN_APP_RELEASE;
sleep 3; # Change when swapping app
done
# Grab the update lockfile
lockfile /tmp/resin/resin-updates.lock
echo "Starting device container"
