Hi! I’ve encountered an issue a handful of times where the modem does not reconnect properly until reset (re-activating the connection solves the issue) i.e nmcli con up xxx
On this post Never reconnected after SIM desactivate/activate I found that it may be that the mobile operator issues a disconnection and the modem does not reconnect by itself. I have a gut feeling that this may be the same issue as what I am experiencing.
This has happened two or three times now, rendering the device unreachable since we are 9 times out of 10 relying solely on cellular connectivity.
Any chance anybody else has experienced the same issue and has found a solution? ![]()
Here’s my current configuration:
[connection]
id=Cellular
uuid=11a739cc-fae9-4be2-a62a-8e2af06c7283
type=gsm
[gsm]
apn=<redacted>
[serial]
baud=115200
[ipv4]
method=auto
route-metric=25
[ipv6]
addr-gen-mode=stable-privacy
method=auto
Below is also a log dump of what happened, and at roughly 14:20 the connection manually activated using our own UI invoking network manager to activate the connection. The connection was still active according to network manager before manually activating the connection again
Jan 09 05:30:55 01b5eed ModemManager[1210]: [modem0/bearer1] verbose call end reason (3,1067): [cm] detach-with-reattach-lte-nw-detach
Jan 09 05:30:55 01b5eed ModemManager[1210]: [modem0] state changed (connected -> registered)
Jan 09 05:30:55 01b5eed ModemManager[1210]: [modem0/bearer1] connection #16 finished: duration 3600s, tx: 0 bytes, rx: 0 bytes
Jan 09 05:30:55 01b5eed 60e2a8c404a8[1690]: info: NetworkManager.Process.DeviceStateMonitor[0] cdc-wdm0 state changed: Activated -> Failed : ModemNoCarrier
Jan 09 05:30:55 01b5eed ModemManager[1210]: [modem0] 3GPP registration state changed (roaming -> registering)
Jan 09 05:30:55 01b5eed ModemManager[1210]: [modem0] 3GPP registration state changed (registering -> roaming)
Jan 09 05:30:55 01b5eed ModemManager[1210]: [modem0] simple connect started...
Jan 09 05:30:55 01b5eed ModemManager[1210]: [modem0] simple connect state (6/10): register
Jan 09 05:30:55 01b5eed ModemManager[1210]: [modem0] simple connect state (7/10): wait to get packet service state attached
Jan 09 05:30:55 01b5eed ModemManager[1210]: [modem0] simple connect state (8/10): bearer
Jan 09 05:30:55 01b5eed ModemManager[1210]: [modem0] simple connect state (9/10): connect
Jan 09 05:30:55 01b5eed ModemManager[1210]: [modem0] state changed (registered -> connecting)
Jan 09 05:30:55 01b5eed ModemManager[1210]: [modem0] state changed (connecting -> registered)
Jan 09 05:30:55 01b5eed ModemManager[1210]: [modem0/bearer1] QMI IPv4 Settings:
Jan 09 05:30:55 01b5eed ModemManager[1210]: [modem0/bearer1] address: 10.52.80.146/30
Jan 09 05:30:55 01b5eed ModemManager[1210]: [modem0/bearer1] gateway: 10.52.80.145
Jan 09 05:30:55 01b5eed ModemManager[1210]: [modem0/bearer1] DNS #1: 193.181.246.58
Jan 09 05:30:55 01b5eed ModemManager[1210]: [modem0/bearer1] DNS #2: 193.181.246.57
Jan 09 05:30:55 01b5eed ModemManager[1210]: [modem0/bearer1] MTU: 1500
Jan 09 05:30:56 01b5eed ModemManager[1210]: [modem0/bearer1] couldn't start network: QMI protocol error (14): 'CallFailed'
Jan 09 05:30:56 01b5eed ModemManager[1210]: [modem0/bearer1] verbose call end reason (2,231): [internal] ip-version-mismatch
Jan 09 05:30:56 01b5eed ModemManager[1210]: [modem0/bearer1] reloading stats is supported by the device
Jan 09 05:30:56 01b5eed ModemManager[1210]: [modem0] state changed (registered -> connected)
Jan 09 05:30:56 01b5eed ModemManager[1210]: [modem0] simple connect state (10/10): all done
Jan 09 06:30:56 01b5eed ModemManager[1210]: [modem0/bearer1] verbose call end reason (3,1067): [cm] detach-with-reattach-lte-nw-detach
Jan 09 06:30:56 01b5eed ModemManager[1210]: [modem0] state changed (connected -> registered)
Jan 09 06:30:56 01b5eed ModemManager[1210]: [modem0/bearer1] connection #17 finished: duration 3600s, tx: 0 bytes, rx: 0 bytes
Jan 09 06:30:56 01b5eed 60e2a8c404a8[1690]: info: NetworkManager.Process.DeviceStateMonitor[0] cdc-wdm0 state changed: Activated -> Failed : ModemNoCarrier
Jan 09 06:30:57 01b5eed ModemManager[1210]: [modem0] 3GPP registration state changed (roaming -> registering)
Jan 09 06:30:57 01b5eed ModemManager[1210]: [modem0] 3GPP registration state changed (registering -> roaming)
Jan 09 06:30:57 01b5eed ModemManager[1210]: [modem0] simple connect started...
Jan 09 06:30:57 01b5eed ModemManager[1210]: [modem0] simple connect state (6/10): register
Jan 09 06:30:57 01b5eed ModemManager[1210]: [modem0] simple connect state (7/10): wait to get packet service state attached
Jan 09 06:30:57 01b5eed ModemManager[1210]: [modem0] simple connect state (8/10): bearer
Jan 09 06:30:57 01b5eed ModemManager[1210]: [modem0] simple connect state (9/10): connect
Jan 09 06:30:57 01b5eed ModemManager[1210]: [modem0] state changed (registered -> connecting)
Jan 09 06:30:57 01b5eed ModemManager[1210]: [modem0] state changed (connecting -> registered)
Jan 09 06:30:58 01b5eed ModemManager[1210]: [modem0/bearer1] QMI IPv4 Settings:
Jan 09 06:30:58 01b5eed ModemManager[1210]: [modem0/bearer1] address: 10.103.97.253/30
Jan 09 06:30:58 01b5eed ModemManager[1210]: [modem0/bearer1] gateway: 10.103.97.254
Jan 09 06:30:58 01b5eed ModemManager[1210]: [modem0/bearer1] DNS #1: 193.181.246.58
Jan 09 06:30:58 01b5eed ModemManager[1210]: [modem0/bearer1] DNS #2: 193.181.246.57
Jan 09 06:30:58 01b5eed ModemManager[1210]: [modem0/bearer1] MTU: 1500
Jan 09 06:30:58 01b5eed ModemManager[1210]: [modem0/bearer1] couldn't start network: QMI protocol error (14): 'CallFailed'
Jan 09 06:30:58 01b5eed ModemManager[1210]: [modem0/bearer1] verbose call end reason (2,231): [internal] ip-version-mismatch
Jan 09 06:30:58 01b5eed ModemManager[1210]: [modem0/bearer1] reloading stats is supported by the device
Jan 09 06:30:58 01b5eed ModemManager[1210]: [modem0] state changed (registered -> connected)
Jan 09 06:30:58 01b5eed ModemManager[1210]: [modem0] simple connect state (10/10): all done
Jan 09 07:30:58 01b5eed ModemManager[1210]: [modem0/bearer1] verbose call end reason (3,1067): [cm] detach-with-reattach-lte-nw-detach
Jan 09 07:30:58 01b5eed ModemManager[1210]: [modem0] state changed (connected -> registered)
Jan 09 07:30:58 01b5eed ModemManager[1210]: [modem0/bearer1] connection #18 finished: duration 3600s, tx: 0 bytes, rx: 0 bytes
Jan 09 07:30:58 01b5eed 60e2a8c404a8[1690]: info: NetworkManager.Process.DeviceStateMonitor[0] cdc-wdm0 state changed: Activated -> Failed : ModemNoCarrier
Jan 09 07:30:58 01b5eed ModemManager[1210]: [modem0] 3GPP registration state changed (roaming -> registering)
Jan 09 07:30:58 01b5eed ModemManager[1210]: [modem0] 3GPP registration state changed (registering -> roaming)
Jan 09 07:30:58 01b5eed ModemManager[1210]: [modem0] simple connect started...
Jan 09 07:30:58 01b5eed ModemManager[1210]: [modem0] simple connect state (6/10): register
Jan 09 07:30:58 01b5eed ModemManager[1210]: [modem0] simple connect state (7/10): wait to get packet service state attached
Jan 09 07:30:59 01b5eed ModemManager[1210]: [modem0] 3GPP registration state changed (roaming -> registering)
Jan 09 07:30:59 01b5eed ModemManager[1210]: [modem0] 3GPP registration state changed (registering -> roaming)
Jan 09 07:30:59 01b5eed ModemManager[1210]: [modem0] simple connect state (8/10): bearer
Jan 09 07:30:59 01b5eed ModemManager[1210]: [modem0] simple connect state (9/10): connect
Jan 09 07:30:59 01b5eed ModemManager[1210]: [modem0] state changed (registered -> connecting)
Jan 09 07:30:59 01b5eed ModemManager[1210]: [modem0] state changed (connecting -> registered)
Jan 09 07:30:59 01b5eed ModemManager[1210]: [modem0/bearer1] QMI IPv4 Settings:
Jan 09 07:30:59 01b5eed ModemManager[1210]: [modem0/bearer1] address: 10.99.146.19/29
Jan 09 07:30:59 01b5eed ModemManager[1210]: [modem0/bearer1] gateway: 10.99.146.20
Jan 09 07:30:59 01b5eed ModemManager[1210]: [modem0/bearer1] DNS #1: 193.181.246.58
Jan 09 07:30:59 01b5eed ModemManager[1210]: [modem0/bearer1] DNS #2: 193.181.246.57
Jan 09 07:30:59 01b5eed ModemManager[1210]: [modem0/bearer1] MTU: 1500
Jan 09 07:30:59 01b5eed ModemManager[1210]: [modem0/bearer1] couldn't start network: QMI protocol error (14): 'CallFailed'
Jan 09 07:30:59 01b5eed ModemManager[1210]: [modem0/bearer1] verbose call end reason (2,231): [internal] ip-version-mismatch
Jan 09 07:31:00 01b5eed ModemManager[1210]: [modem0/bearer1] reloading stats is supported by the device
Jan 09 07:31:00 01b5eed ModemManager[1210]: [modem0] state changed (registered -> connected)
Jan 09 07:31:00 01b5eed ModemManager[1210]: [modem0] simple connect state (10/10): all done
Jan 09 10:41:09 01b5eed ModemManager[1210]: [modem0] network reject indication received
Jan 09 10:41:09 01b5eed ModemManager[1210]: [modem0] service domain: ps
Jan 09 10:41:09 01b5eed ModemManager[1210]: [modem0] radio interface: lte
Jan 09 10:41:09 01b5eed ModemManager[1210]: [modem0] reject cause: implicitly-detached
Jan 09 10:41:09 01b5eed ModemManager[1210]: [modem0/bearer1] verbose call end reason (3,1028): [cm] emm-detached
Jan 09 10:41:09 01b5eed ModemManager[1210]: [modem0] state changed (connected -> registered)
Jan 09 10:41:09 01b5eed ModemManager[1210]: [modem0/bearer1] connection #19 finished: duration 11409s, tx: 0 bytes, rx: 0 bytes
Jan 09 10:41:09 01b5eed 60e2a8c404a8[1690]: info: NetworkManager.Process.DeviceStateMonitor[0] cdc-wdm0 state changed: Activated -> Failed : ModemNoCarrier
Jan 09 10:41:09 01b5eed ModemManager[1210]: [modem0] 3GPP registration state changed (roaming -> registering)
Jan 09 10:41:09 01b5eed ModemManager[1210]: [modem0] 3GPP registration state changed (registering -> roaming)
Jan 09 10:41:09 01b5eed ModemManager[1210]: [modem0] simple connect started...
Jan 09 10:41:09 01b5eed ModemManager[1210]: [modem0] simple connect state (6/10): register
Jan 09 10:41:09 01b5eed ModemManager[1210]: [modem0] simple connect state (7/10): wait to get packet service state attached
Jan 09 10:41:10 01b5eed ModemManager[1210]: [modem0] 3GPP registration state changed (roaming -> registering)
Jan 09 10:41:10 01b5eed ModemManager[1210]: [modem0] 3GPP registration state changed (registering -> roaming)
Jan 09 10:41:10 01b5eed ModemManager[1210]: [modem0] simple connect state (8/10): bearer
Jan 09 10:41:10 01b5eed ModemManager[1210]: [modem0] simple connect state (9/10): connect
Jan 09 10:41:10 01b5eed ModemManager[1210]: [modem0] state changed (registered -> connecting)
Jan 09 10:41:10 01b5eed ModemManager[1210]: [modem0] state changed (connecting -> registered)
Jan 09 10:41:11 01b5eed ModemManager[1210]: [modem0/bearer1] QMI IPv4 Settings:
Jan 09 10:41:11 01b5eed ModemManager[1210]: [modem0/bearer1] address: 10.127.201.45/30
Jan 09 10:41:11 01b5eed ModemManager[1210]: [modem0/bearer1] gateway: 10.127.201.46
Jan 09 10:41:11 01b5eed ModemManager[1210]: [modem0/bearer1] DNS #1: 193.181.246.58
Jan 09 10:41:11 01b5eed ModemManager[1210]: [modem0/bearer1] DNS #2: 193.181.246.57
Jan 09 10:41:11 01b5eed ModemManager[1210]: [modem0/bearer1] MTU: 1500
Jan 09 10:41:11 01b5eed ModemManager[1210]: [modem0/bearer1] couldn't start network: QMI protocol error (14): 'CallFailed'
Jan 09 10:41:11 01b5eed ModemManager[1210]: [modem0/bearer1] verbose call end reason (2,231): [internal] ip-version-mismatch
Jan 09 10:41:11 01b5eed ModemManager[1210]: [modem0/bearer1] reloading stats is supported by the device
Jan 09 10:41:11 01b5eed ModemManager[1210]: [modem0] state changed (registered -> connected)
Jan 09 10:41:11 01b5eed ModemManager[1210]: [modem0] simple connect state (10/10): all done
Jan 09 11:41:11 01b5eed ModemManager[1210]: [modem0/bearer1] verbose call end reason (3,1067): [cm] detach-with-reattach-lte-nw-detach
Jan 09 11:41:11 01b5eed ModemManager[1210]: [modem0] state changed (connected -> registered)
Jan 09 11:41:11 01b5eed ModemManager[1210]: [modem0/bearer1] connection #20 finished: duration 3600s, tx: 0 bytes, rx: 0 bytes
Jan 09 11:41:12 01b5eed 60e2a8c404a8[1690]: info: NetworkManager.Process.DeviceStateMonitor[0] cdc-wdm0 state changed: Activated -> Failed : ModemNoCarrier
Jan 09 11:41:12 01b5eed ModemManager[1210]: [modem0] 3GPP registration state changed (roaming -> registering)
Jan 09 11:41:12 01b5eed ModemManager[1210]: [modem0] 3GPP registration state changed (registering -> roaming)
Jan 09 11:41:12 01b5eed ModemManager[1210]: [modem0] simple connect started...
Jan 09 11:41:12 01b5eed ModemManager[1210]: [modem0] simple connect state (6/10): register
Jan 09 11:41:12 01b5eed ModemManager[1210]: [modem0] simple connect state (7/10): wait to get packet service state attached
Jan 09 11:41:12 01b5eed ModemManager[1210]: [modem0] simple connect state (8/10): bearer
Jan 09 11:41:12 01b5eed ModemManager[1210]: [modem0] simple connect state (9/10): connect
Jan 09 11:41:12 01b5eed ModemManager[1210]: [modem0] state changed (registered -> connecting)
Jan 09 11:41:12 01b5eed ModemManager[1210]: [modem0] state changed (connecting -> registered)
Jan 09 11:41:12 01b5eed ModemManager[1210]: [modem0/bearer1] QMI IPv4 Settings:
Jan 09 11:41:12 01b5eed ModemManager[1210]: [modem0/bearer1] address: 10.102.93.142/30
Jan 09 11:41:12 01b5eed ModemManager[1210]: [modem0/bearer1] gateway: 10.102.93.141
Jan 09 11:41:12 01b5eed ModemManager[1210]: [modem0/bearer1] DNS #1: 193.181.246.58
Jan 09 11:41:12 01b5eed ModemManager[1210]: [modem0/bearer1] DNS #2: 193.181.246.57
Jan 09 11:41:12 01b5eed ModemManager[1210]: [modem0/bearer1] MTU: 1500
Jan 09 11:41:13 01b5eed ModemManager[1210]: [modem0/bearer1] couldn't start network: QMI protocol error (14): 'CallFailed'
Jan 09 11:41:13 01b5eed ModemManager[1210]: [modem0/bearer1] verbose call end reason (2,231): [internal] ip-version-mismatch
Jan 09 11:41:13 01b5eed ModemManager[1210]: [modem0/bearer1] reloading stats is supported by the device
Jan 09 11:41:13 01b5eed ModemManager[1210]: [modem0] state changed (registered -> connected)
Jan 09 11:41:13 01b5eed ModemManager[1210]: [modem0] simple connect state (10/10): all done
Jan 09 14:18:00 01b5eed ModemManager[1210]: [modem0] state changed (connected -> disconnecting)
Jan 09 14:18:00 01b5eed ModemManager[1210]: [modem0] network reject indication received
Jan 09 14:18:00 01b5eed ModemManager[1210]: [modem0] service domain: ps
Jan 09 14:18:00 01b5eed ModemManager[1210]: [modem0] radio interface: lte
Jan 09 14:18:00 01b5eed ModemManager[1210]: [modem0] reject cause: implicitly-detached
Jan 09 14:18:00 01b5eed ModemManager[1210]: [modem0] state changed (disconnecting -> registered)
Jan 09 14:18:00 01b5eed ModemManager[1210]: [modem0/bearer1] connection #21 finished: duration 9407s, tx: 0 bytes, rx: 0 bytes
Jan 09 14:18:01 01b5eed ModemManager[1210]: [modem0] simple connect started...
Jan 09 14:18:01 01b5eed ModemManager[1210]: [modem0] simple connect state (6/10): register
Jan 09 14:18:01 01b5eed ModemManager[1210]: [modem0] simple connect state (7/10): wait to get packet service state attached
Jan 09 14:18:01 01b5eed ModemManager[1210]: [modem0] simple connect state (8/10): bearer
Jan 09 14:18:01 01b5eed ModemManager[1210]: [modem0] simple connect state (9/10): connect
Jan 09 14:18:01 01b5eed ModemManager[1210]: [modem0] state changed (registered -> connecting)
Jan 09 14:18:01 01b5eed ModemManager[1210]: [modem0] 3GPP registration state changed (roaming -> registering)
Jan 09 14:18:01 01b5eed ModemManager[1210]: [modem0] 3GPP registration state changed (registering -> roaming)
Jan 09 14:18:01 01b5eed ModemManager[1210]: [modem0] state changed (connecting -> registered)
Jan 09 14:18:01 01b5eed ModemManager[1210]: [modem0/bearer1] couldn't start network: QMI protocol error (14): 'CallFailed'
Jan 09 14:18:01 01b5eed ModemManager[1210]: [modem0/bearer1] verbose call end reason (3,2001): [cm] no-service
Jan 09 14:18:01 01b5eed ModemManager[1210]: [modem0/bearer1] verbose call end reason (2,231): [internal] ip-version-mismatch
Jan 09 14:18:01 01b5eed ModemManager[1210]: [modem0/bearer1] connection attempt #22 failed: Call failed: cm error: no-service
Jan 09 14:18:01 01b5eed ModemManager[1210]: [modem0/bearer1] connection #22 finished: duration 0s, tx: 0 bytes, rx: 0 bytes
Jan 09 14:18:02 01b5eed ModemManager[1210]: [modem0/bearer2] QMI IPv4 Settings:
Jan 09 14:18:02 01b5eed ModemManager[1210]: [modem0/bearer2] address: 10.99.228.228/29
Jan 09 14:18:02 01b5eed ModemManager[1210]: [modem0/bearer2] gateway: 10.99.228.229
Jan 09 14:18:02 01b5eed ModemManager[1210]: [modem0/bearer2] DNS #1: 193.181.246.58
Jan 09 14:18:02 01b5eed ModemManager[1210]: [modem0/bearer2] DNS #2: 193.181.246.57
Jan 09 14:18:02 01b5eed ModemManager[1210]: [modem0/bearer2] MTU: 1500
Jan 09 14:18:02 01b5eed ModemManager[1210]: [modem0/bearer2] reloading stats is supported by the device
Jan 09 14:18:02 01b5eed ModemManager[1210]: [modem0] state changed (registered -> connected)
Jan 09 14:18:02 01b5eed ModemManager[1210]: [modem0] simple connect state (10/10): all done
Jan 09 14:18:59 01b5eed ModemManager[1210]: [modem0] state changed (connected -> disconnecting)
Jan 09 14:18:59 01b5eed ModemManager[1210]: [modem0] state changed (disconnecting -> registered)
Jan 09 14:18:59 01b5eed ModemManager[1210]: [modem0/bearer2] connection #2 finished: duration 57s, tx: 0 bytes, rx: 0 bytes
Jan 09 14:19:00 01b5eed ModemManager[1210]: [modem0] simple connect started...
Jan 09 14:19:00 01b5eed ModemManager[1210]: [modem0] simple connect state (6/10): register
Jan 09 14:19:00 01b5eed ModemManager[1210]: [modem0] simple connect state (7/10): wait to get packet service state attached
Jan 09 14:19:00 01b5eed ModemManager[1210]: [modem0] simple connect state (8/10): bearer
Jan 09 14:19:00 01b5eed ModemManager[1210]: [modem0] simple connect state (9/10): connect
Jan 09 14:19:00 01b5eed ModemManager[1210]: [modem0] state changed (registered -> connecting)
Jan 09 14:19:00 01b5eed ModemManager[1210]: [modem0/bearer1] QMI IPv4 Settings:
Jan 09 14:19:00 01b5eed ModemManager[1210]: [modem0/bearer1] address: 10.100.22.169/30
Jan 09 14:19:00 01b5eed ModemManager[1210]: [modem0/bearer1] gateway: 10.100.22.170
Jan 09 14:19:00 01b5eed ModemManager[1210]: [modem0/bearer1] DNS #1: 193.181.246.58
Jan 09 14:19:00 01b5eed ModemManager[1210]: [modem0/bearer1] DNS #2: 193.181.246.57
Jan 09 14:19:00 01b5eed ModemManager[1210]: [modem0/bearer1] MTU: 1500
Jan 09 14:19:00 01b5eed ModemManager[1210]: [modem0/bearer1] couldn't start network: QMI protocol error (14): 'CallFailed'
Jan 09 14:19:00 01b5eed ModemManager[1210]: [modem0/bearer1] verbose call end reason (2,231): [internal] ip-version-mismatch
Jan 09 14:19:00 01b5eed ModemManager[1210]: [modem0/bearer1] reloading stats is supported by the device
Jan 09 14:19:00 01b5eed ModemManager[1210]: [modem0] state changed (connecting -> connected)
Jan 09 14:19:00 01b5eed ModemManager[1210]: [modem0] simple connect state (10/10): all done
Jan 09 14:20:46 01b5eed ModemManager[1210]: [modem0] state changed (connected -> disconnecting)
Jan 09 14:20:47 01b5eed ModemManager[1210]: [modem0] state changed (disconnecting -> registered)
Jan 09 14:20:47 01b5eed ModemManager[1210]: [modem0/bearer1] connection #23 finished: duration 106s, tx: 11484 bytes, rx: 32537 bytes
Jan 09 14:20:47 01b5eed ModemManager[1210]: [modem0] simple connect started...
Jan 09 14:20:47 01b5eed ModemManager[1210]: [modem0] simple connect state (6/10): register
Jan 09 14:20:47 01b5eed ModemManager[1210]: [modem0] simple connect state (7/10): wait to get packet service state attached
Jan 09 14:20:47 01b5eed ModemManager[1210]: [modem0] simple connect state (8/10): bearer
Jan 09 14:20:47 01b5eed ModemManager[1210]: [modem0] simple connect state (9/10): connect
Jan 09 14:20:47 01b5eed ModemManager[1210]: [modem0] state changed (registered -> connecting)
Jan 09 14:20:47 01b5eed ModemManager[1210]: [modem0/bearer1] QMI IPv4 Settings:
Jan 09 14:20:47 01b5eed ModemManager[1210]: [modem0/bearer1] address: 10.100.117.94/30
Jan 09 14:20:47 01b5eed ModemManager[1210]: [modem0/bearer1] gateway: 10.100.117.93
Jan 09 14:20:47 01b5eed ModemManager[1210]: [modem0/bearer1] DNS #1: 193.181.246.58
Jan 09 14:20:47 01b5eed ModemManager[1210]: [modem0/bearer1] DNS #2: 193.181.246.57
Jan 09 14:20:47 01b5eed ModemManager[1210]: [modem0/bearer1] MTU: 1500
Jan 09 14:20:47 01b5eed ModemManager[1210]: [modem0/bearer1] couldn't start network: QMI protocol error (14): 'CallFailed'
Jan 09 14:20:47 01b5eed ModemManager[1210]: [modem0/bearer1] verbose call end reason (2,231): [internal] ip-version-mismatch
Jan 09 14:20:47 01b5eed ModemManager[1210]: [modem0/bearer1] reloading stats is supported by the device
Jan 09 14:20:47 01b5eed ModemManager[1210]: [modem0] state changed (connecting -> connected)
Jan 09 14:20:47 01b5eed ModemManager[1210]: [modem0] simple connect state (10/10): all done
Jan 09 14:21:20 01b5eed ModemManager[1210]: [modem0] state changed (connected -> disconnecting)
Jan 09 14:21:20 01b5eed ModemManager[1210]: [modem0] state changed (disconnecting -> registered)
Jan 09 14:21:20 01b5eed ModemManager[1210]: [modem0/bearer1] connection #24 finished: duration 32s, tx: 12353 bytes, rx: 35814 bytes
Jan 09 14:21:20 01b5eed ModemManager[1210]: [modem0] simple connect started...
Jan 09 14:21:20 01b5eed ModemManager[1210]: [modem0] simple connect state (6/10): register
Jan 09 14:21:20 01b5eed ModemManager[1210]: [modem0] simple connect state (7/10): wait to get packet service state attached
Jan 09 14:21:20 01b5eed ModemManager[1210]: [modem0] simple connect state (8/10): bearer
Jan 09 14:21:20 01b5eed ModemManager[1210]: [modem0] simple connect state (9/10): connect
Jan 09 14:21:20 01b5eed ModemManager[1210]: [modem0] state changed (registered -> connecting)
Jan 09 14:21:21 01b5eed ModemManager[1210]: [modem0/bearer1] QMI IPv4 Settings:
Jan 09 14:21:21 01b5eed ModemManager[1210]: [modem0/bearer1] address: 10.100.146.113/30
Jan 09 14:21:21 01b5eed ModemManager[1210]: [modem0/bearer1] gateway: 10.100.146.114
Jan 09 14:21:21 01b5eed ModemManager[1210]: [modem0/bearer1] DNS #1: 193.181.246.58
Jan 09 14:21:21 01b5eed ModemManager[1210]: [modem0/bearer1] DNS #2: 193.181.246.57
Jan 09 14:21:21 01b5eed ModemManager[1210]: [modem0/bearer1] MTU: 1500
Jan 09 14:21:21 01b5eed ModemManager[1210]: [modem0/bearer1] couldn't start network: QMI protocol error (14): 'CallFailed'
Jan 09 14:21:21 01b5eed ModemManager[1210]: [modem0/bearer1] verbose call end reason (2,231): [internal] ip-version-mismatch
Jan 09 14:21:21 01b5eed ModemManager[1210]: [modem0/bearer1] reloading stats is supported by the device
Jan 09 14:21:21 01b5eed ModemManager[1210]: [modem0] state changed (connecting -> connected)
Jan 09 14:21:21 01b5eed ModemManager[1210]: [modem0] simple connect state (10/10): all done
