mmcli stuck in registered state?
Having a little trouble with mmcli and a sixfab 4g iot hat. Here’s what I’ve got:
Everything seems fine, strong signal, correct network (tmobile), gps fix with accurate lat/long, and even the correct mobile phone number (see Numbers below). But for some reason it remains in Status: state: registered. Which yields a disconnected state in nmcli and no cellular IP address in balenacloud ui.
Any ideas? I had thought perhaps it was an APN problem but I tripled checked that, or that it was a registration problem with iotDataworks, but that also seems fine per the Number matching automatically what they said belonged to my sim.
root@fff19d1:~# mmcli -m 0
  General  |               dbus path: /org/freedesktop/ModemManager1/Modem/0
           |               device id: [redacted]
  Hardware |            manufacturer: QUALCOMM INCORPORATED
           |                   model: QUECTEL Mobile Broadband Module
           |       firmware revision: EG25GGBR07A08M2G
           |          carrier config: Commercial-TMO_VoLTE
           | carrier config revision: 05010505
           |            h/w revision: 10000
           |               supported: gsm-umts, lte
           |                 current: gsm-umts, lte
           |            equipment id: [redacted]
  System   |                  device: /sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3
           |                 drivers: option1, qmi_wwan
           |                  plugin: quectel
           |            primary port: cdc-wdm0
           |                   ports: cdc-wdm0 (qmi), ttyUSB0 (qcdm), ttyUSB2 (at),
           |                          ttyUSB1 (gps), wwp1s0u1u3i4 (net), ttyUSB3 (at)
  Numbers  |                     own: 1523[redacted]
  Status   |                    lock: sim-pin2
           |          unlock retries: sim-pin (3), sim-puk (10), sim-pin2 (10), sim-puk2 (10)
           |                   state: registered
           |             power state: on
           |             access tech: lte
           |          signal quality: 68% (recent)
  Modes    |               supported: allowed: 2g; preferred: none
           |                          allowed: 3g; preferred: none
           |                          allowed: 4g; preferred: none
           |                          allowed: 2g, 3g; preferred: 3g
           |                          allowed: 2g, 3g; preferred: 2g
           |                          allowed: 2g, 4g; preferred: 4g
           |                          allowed: 2g, 4g; preferred: 2g
           |                          allowed: 3g, 4g; preferred: 4g
           |                          allowed: 3g, 4g; preferred: 3g
           |                          allowed: 2g, 3g, 4g; preferred: 4g
           |                          allowed: 2g, 3g, 4g; preferred: 3g
           |                          allowed: 2g, 3g, 4g; preferred: 2g
           |                 current: allowed: 2g, 3g, 4g; preferred: 4g
  Bands    |               supported: egsm, dcs, pcs, g850, utran-1, utran-4, utran-6, utran-5,
           |                          utran-8, utran-2, eutran-1, eutran-2, eutran-3, eutran-4, eutran-5,
           |                          eutran-7, eutran-8, eutran-12, eutran-13, eutran-18, eutran-19,
           |                          eutran-20, eutran-25, eutran-26, eutran-28, eutran-38, eutran-39,
           |                          eutran-40, eutran-41, utran-19
           |                 current: egsm, dcs, pcs, g850, utran-1, utran-4, utran-6, utran-5,
  IP       |               supported: ipv4, ipv6, ipv4v6
  3GPP     |                    imei: [redacted]
           |             operator id: 310260
           |           operator name: T-Mobile
           |            registration: home
  3GPP EPS |    ue mode of operation: csps-1
  SIM      |               dbus path: /org/freedesktop/ModemManager1/SIM/0
  Bearer   |               dbus path: /org/freedesktop/ModemManager1/Bearer/0
And, nmcli shows no connection on cellular.
> root@fff19d1:~# nmcli
>     cdc-wdm0: disconnected
>             "cdc-wdm0"
>             gsm (option1, qmi_wwan), hw
Update, I should have tried this earlier but I just tested with a different sim from twilio instead and it works. Looks like I need to check in with iotdataworks.
Whoops
I may have spoken a little too soon. Oddly, mmcli shows that I am connected, but it isn’t playing nice with nmcli. Apologies in advance, below output is big. But the main issue I believe is this:
Everything looks fine on the ModemManager side…
mmcli -m 0
state: connected
primary port: cdc-wdm0.
Seems like we’re all good, which is where I left the last post … But, NetworkManager doesn’t seem to agree with that.
nmcli
And if I did a little further, it appears to not be able to find the hardware?
nmcli device show
GENERAL.HWADDR: (unknown) GENERAL.STATE: 30 (disconnected).
What could cause the disagreement between ModemManager and NetworkManager?
Full output:
           |            h/w revision: 10000
           |                  plugin: quectel
  Numbers  |                     own: [redacted]
           |                   state: connected
           |             power state: on
           |             access tech: lte
           |          signal quality: 84% (recent)
           |             operator id: 310260
           |           operator name: Twilio
           |            registration: home
eth0: connected to Wired connection 1
        "eth0"
        ethernet (bcmgenet), DC:[redacted]:52, hw, mtu 1500
        ip4 default
        inet4 192.168.1.55/24
        route4 0.0.0.0/0
        route4 192.168.1.0/24
        inet6 fd3a:414f:9b6b:1:fef2:34bd:7ac5:6896/64
        inet6 fe80::aec9:dc68:482f:d5d2/64
        route6 fd3a:414f:9b6b::/64
        route6 fd3a:414f:9b6b:1::/64
        route6 ff00::/8
        route6 fe80::/64
wlan0: connected to resin-wifi-01
        "wlan0"
        wifi (brcmfmac), DC:[redacted]:54, hw, mtu 1500
        inet4 192.168.1.69/24
        route4 0.0.0.0/0
        inet6 fd3a:414f:9b6b:1:5b2:2a5:c524:2c07/64
        inet6 fe80::741e:6dc3:90bb:c8df/64
        route6 ff00::/8
        route6 fe80::/64
supervisor0: connected (externally) to supervisor0
        "supervisor0"
        bridge, 02:42:D6:BD:E5:74, sw, mtu 1500
        inet4 10.114.104.1/25
        route4 10.114.104.0/25
        "cdc-wdm0"
balena0: unmanaged
        "balena0"
        bridge, 02:42:F1:A7:53:36, sw, mtu 1500
br-859fdb826d9e: unmanaged
        "br-859fdb826d9e"
        bridge, 02:42:5E:B4:3A:53, sw, mtu 1500
resin-dns: unmanaged
        "resin-dns"
        bridge, DE:8B:69:85:D8:38, sw, mtu 1500
lo: unmanaged
        "lo"
        loopback (unknown), 00:00:00:00:00:00, sw, mtu 65536
resin-vpn: unmanaged
        "resin-vpn"
        tun, sw, mtu 1500
DNS configuration:
        servers: 192.168.1.1
        interface: eth0
        interface: wlan0
Use "nmcli device show" to get complete information about known devices and
"nmcli connection show" to get an overview on active connection profiles.
Consult nmcli(1) and nmcli-examples(7) manual pages for complete usage details.
root@fff19d1:~# nmcli device show
GENERAL.DEVICE:                         eth0
GENERAL.TYPE:                           ethernet
GENERAL.HWADDR:                         DC:[redacted]:52
GENERAL.MTU:                            1500
GENERAL.STATE:                          100 (connected)
GENERAL.CONNECTION:                     Wired connection 1
GENERAL.CON-PATH:                       /org/freedesktop/NetworkManager/ActiveConnection/3
WIRED-PROPERTIES.CARRIER:               on
IP4.ADDRESS[1]:                         192.168.1.55/24
IP4.GATEWAY:                            192.168.1.1
IP4.ROUTE[1]:                           dst = 0.0.0.0/0, nh = 192.168.1.1, mt = 100
IP4.ROUTE[2]:                           dst = 192.168.1.0/24, nh = 0.0.0.0, mt = 100
IP4.DNS[1]:                             192.168.1.1
IP6.ADDRESS[1]:                         fd3a:414f:9b6b:1:fef2:34bd:7ac5:6896/64
IP6.ADDRESS[2]:                         fe80::aec9:dc68:482f:d5d2/64
IP6.GATEWAY:                            --
IP6.ROUTE[1]:                           dst = fd3a:414f:9b6b::/64, nh = fe80::c78:2dc9:65e6:8f81, mt = 100
IP6.ROUTE[2]:                           dst = fd3a:414f:9b6b:1::/64, nh = ::, mt = 100
IP6.ROUTE[3]:                           dst = ff00::/8, nh = ::, mt = 256, table=255
IP6.ROUTE[4]:                           dst = fe80::/64, nh = ::, mt = 100
GENERAL.DEVICE:                         wlan0
GENERAL.TYPE:                           wifi
GENERAL.HWADDR:                         DC:[redacted]:54
GENERAL.MTU:                            1500
GENERAL.CONNECTION:                     resin-wifi-01
GENERAL.CON-PATH:                       /org/freedesktop/NetworkManager/ActiveConnection/2
IP4.ADDRESS[1]:                         192.168.1.69/24
IP4.ROUTE[1]:                           dst = 0.0.0.0/0, nh = 192.168.1.1, mt = 600
IP4.ROUTE[2]:                           dst = 192.168.1.0/24, nh = 0.0.0.0, mt = 600
IP6.ADDRESS[1]:                         fd3a:414f:9b6b:1:5b2:2a5:c524:2c07/64
IP6.ADDRESS[2]:                         fe80::741e:6dc3:90bb:c8df/64
IP6.GATEWAY:                            --
IP6.ROUTE[1]:                           dst = fd3a:414f:9b6b::/64, nh = fe80::c78:2dc9:65e6:8f81, mt = 600
IP6.ROUTE[2]:                           dst = fd3a:414f:9b6b:1::/64, nh = ::, mt = 600
IP6.ROUTE[4]:                           dst = fe80::/64, nh = ::, mt = 600
GENERAL.DEVICE:                         supervisor0
GENERAL.TYPE:                           bridge
GENERAL.HWADDR:                         02:42:D6:BD:E5:74
GENERAL.MTU:                            1500
GENERAL.STATE:                          100 (connected (externally))
GENERAL.CONNECTION:                     supervisor0
GENERAL.CON-PATH:                       /org/freedesktop/NetworkManager/ActiveConnection/1
IP4.ADDRESS[1]:                         10.114.104.1/25
IP4.GATEWAY:                            --
IP4.ROUTE[1]:                           dst = 10.114.104.0/25, nh = 0.0.0.0, mt = 0
IP6.GATEWAY:                            --
GENERAL.DEVICE:                         cdc-wdm0
GENERAL.TYPE:                           gsm
GENERAL.MTU:                            0
GENERAL.CONNECTION:                     --
GENERAL.CON-PATH:                       --
GENERAL.DEVICE:                         balena0
GENERAL.HWADDR:                         02:42:F1:A7:53:36
GENERAL.MTU:                            1500
GENERAL.STATE:                          10 (unmanaged)
IP4.ADDRESS[1]:                         10.114.101.1/24
IP4.GATEWAY:                            --
IP4.ROUTE[1]:                           dst = 10.114.101.0/24, nh = 0.0.0.0, mt = 0
IP6.GATEWAY:                            --
GENERAL.DEVICE:                         br-859fdb826d9e
GENERAL.HWADDR:                         02:42:5E:B4:3A:53
GENERAL.MTU:                            1500
IP4.ADDRESS[1]:                         172.17.0.1/16
IP4.GATEWAY:                            --
IP4.ROUTE[1]:                           dst = 172.17.0.0/16, nh = 0.0.0.0, mt = 0
IP6.GATEWAY:                            --
GENERAL.DEVICE:                         resin-dns
GENERAL.HWADDR:                         DE:8B:69:85:D8:38
GENERAL.MTU:                            1500
IP4.ADDRESS[1]:                         10.114.102.1/24
IP4.GATEWAY:                            --
IP4.ROUTE[1]:                           dst = 10.114.102.0/24, nh = 0.0.0.0, mt = 0
IP6.GATEWAY:                            --
GENERAL.DEVICE:                         lo
GENERAL.TYPE:                           loopback
GENERAL.HWADDR:                         00:00:00:00:00:00
GENERAL.MTU:                            65536
IP4.ADDRESS[1]:                         127.0.0.1/8
IP4.GATEWAY:                            --
IP6.ADDRESS[1]:                         ::1/128
IP6.GATEWAY:                            --
IP6.ROUTE[1]:                           dst = ::1/128, nh = ::, mt = 256
GENERAL.DEVICE:                         resin-vpn
GENERAL.TYPE:                           tun
GENERAL.MTU:                            1500
IP4.ADDRESS[1]:                         10.240.104.11/32
IP4.GATEWAY:                            --
IP4.ROUTE[1]:                           dst = 52.4.252.97/32, nh = 0.0.0.0, mt = 0
IP6.ADDRESS[1]:                         fe80::8d39:ed34:2d6e:9c04/64
IP6.GATEWAY:                            --
IP6.ROUTE[1]:                           dst = ff00::/8, nh = ::, mt = 256, table=255
IP6.ROUTE[2]:                           dst = fe80::/64, nh = ::, mt = 256
The saga continues…
Tried two different sims (one from Twilio, which worked in the past and one from IoTDataworks - both use Tmobile). Also, tried a completely different machine (fin3) with a completely different modem (non sixfab, just the mpcie quectel ec25-g) and oddly I’m getting the same stuck in registered problem from mmcli.
Utterly baffled that now two devices with two different modems and two different sims (9 variants tried) would all fail the same way, especially when one worked in the past.
I did some more digging and found this is happening:
Mar 17 23:10:52 59b8278 ModemManager[741]: [/dev/cdc-wdm0] received message...
                                           <<<<<< RAW:
                                           <<<<<<   length = 25
                                           <<<<<<   data   = 01:18:00:80:03:03:02:83:00:20:00:0C:00:02:04:00:00:00:00:00:01:02:00:C1:08
Mar 17 23:10:52 59b8278 ModemManager[741]: [/dev/cdc-wdm0] received generic response (translated)...
                                           <<<<<< QMUX:
                                           <<<<<<   length  = 24
                                           <<<<<<   flags   = 0x80
                                           <<<<<<   service = "nas"
                                           <<<<<<   client  = 3
                                           <<<<<< QMI:
                                           <<<<<<   flags       = "response"
                                           <<<<<<   transaction = 131
                                           <<<<<<   tlv_length  = 12
                                           <<<<<<   message     = "Get Signal Strength" (0x0020)
                                           <<<<<< TLV:
                                           <<<<<<   type       = "Result" (0x02)
                                           <<<<<<   length     = 4
                                           <<<<<<   value      = 00:00:00:00
                                           <<<<<<   translated = SUCCESS
                                           <<<<<< TLV:
                                           <<<<<<   type       = "Signal Strength" (0x01)
                                           <<<<<<   length     = 2
                                           <<<<<<   value      = C1:08
                                           <<<<<<   translated = [ strength = '-63' radio_interface = 'lte' ]
Mar 17 23:10:52 59b8278 ModemManager[741]: Signal strength (lte): -63 dBm
Mar 17 23:10:52 59b8278 ModemManager[741]: Signal strength: -63 dBm --> 81%
Mar 17 23:10:52 59b8278 ModemManager[741]: Modem /org/freedesktop/ModemManager1/Modem/0: signal quality updated (81)
Mar 17 23:10:52 59b8278 ModemManager[741]: Periodic signal quality checks scheduled in 30s
Mar 17 23:11:06 59b8278 ModemManager[741]: (net/veth4ed2d80): adding device at sysfs path: /sys/devices/virtual/net/veth4ed2d80
Mar 17 23:11:06 59b8278 ModemManager[741]: [filter] (net/veth4ed2d80) port filtered: virtual device
Mar 17 23:11:06 59b8278 ModemManager[741]: (net/veth1a80303): adding device at sysfs path: /sys/devices/virtual/net/veth1a80303
Mar 17 23:11:06 59b8278 ModemManager[741]: [filter] (net/veth1a80303) port filtered: virtual device
Mar 17 23:11:06 59b8278 ModemManager[741]: (net/vethf26f229): adding device at sysfs path: /sys/devices/virtual/net/vethf26f229
Mar 17 23:11:06 59b8278 ModemManager[741]: [filter] (net/vethf26f229) port filtered: virtual device
Mar 17 23:11:22 59b8278 ModemManager[741]: loading signal quality...
Plenty of signal quality, but the system seems to keep reassigning the modem to different veths within seconds.
Has anyone seen this before??
Hi, reading through the above thread I have some follow up questions:
  • Have you tested the SIM card on a mobile phone, and made sure it is able to register and work on the carrier’s network?
  • Does that SIM card work on Raspbian on your RPI4 + Hat combination?
If the answer to both the above is yes, I suggest you configure NetwotkManager debug logging with:
nmcli general logging level DEBUG domain ALL
And capture connection logs from both Raspbian and BalenaOS. If you send those logs to us we can then help you debug this further.
So we managed to get this problem solved with the help of @aleksander0m!
The problem it turns out was simply that the profile that modemmanager was trying to connect to was incorrect and needed to be cleared.
Running qmicli -d /dev/cdc-wdm0 -p --wds-get-profile-list=3gpp
Returned:
Profile list retrieved:
        [1] 3gpp -
                APN: 'fast.t-mobile.com'
                PDP type: 'ipv4-or-ipv6'
                PDP context number: '1'
                Username: ''
                Password: ''
                Auth: 'none'
                No roaming: 'no'
                APN disabled: 'no'
Somehow ModemManager ignored the APN defined in our system-connections file and chose fast.t-mobile.com which worked for other SIMs but not the IoTDataWorks SIM which is expecting an APN of m2mglobal.
The solution?
Running qmicli -d /dev/cdc-wdm0 -p --wds-modify-profile="3gpp,1,apn=,pdp-type=ipv4v6"
Cleared that profile and now returns:
[1] 3gpp -
                APN: ''
                Username: ''
                Password: ''
                Auth: 'none'
                No roaming: 'no'
                APN disabled: 'no'
With an empty APN which solved the issue.
Now, WHY did mmcli or qmicli chose that t-mobile APN even though I never defined it (at least I think I didnt)? I’m not sure, but for diagnosing connectivity problems, checking these profiles via qmicli will be a useful tool.
I’ll add that not only did it solve the problem, but the Fin has been running rock solid for weeks on cellular without an issue. Very happy over here.
It’s not that mmcli or qmicli selected that APN, none of those tools would do that.
Your modem is configured to use a specific APN during the LTE registration process, and this happens before you attempt to connect the modem with the user-provided (NetworkManager-provided) APN. This APN used during registration is the one given in the “initial LTE bearer settings”.
In MM git master, you can change these settings with mmcli --3gpp-set-initial-eps-bearer-settings=["key=value,..."] for QMI modems like yours. What this command will do is check which is the 3GPP profile configured to be used during initial attach, and then modify it. In most cases the profile configured for initial attach is the first one, as in your case, and so what you did solved the problem in the same way as we would with the --3gpp-set-initial-eps-bearer-settings operation.
BTW, that fast.t-mobile.com APN was possibly already configured in the module itself, e.g. maybe via carrier configuration or something.
:man_facepalming: This particular modem was purchased used.
I could have saved a whole lot of trouble if I had asked myself “I wonder if the previous owner made some configurations himself”!
@barryjump thanks for posting the detailed explanation and @aleksander0m thanks for helping out :slight_smile:
glad this was sorted
Hi, I am new to NM and MM and started learning as one of our customer is having the same issue with Sierra MC7430 which is in MBIM mode not QMI. I did share this forum with them but they said their APN is set to the right one but still its they are having issue. It says its register to Telstra with good signal but it shows Disconnected.
Can you please help me with this.
Hello @Ek2024 welcome to the balena community!
Did you read this thread? CM4 & Sierra EM7345 Modem - #27 by TJvV
Let us know if this help you!
hy everyone,
i solved my issued with the modem (in our case Quectel EC25 LTE) by activating the xHCI USB3.0 Controller on my PI4 (computeModule)
add this line at the end of this file:
otg_mode=1
/mnt/boot/config.txt
Better way is to configure the value with the balena CLI or API, for that use this ENV Variable:
BALENA_HOST_CONFIG_otg_mode
This will activate the USB3.0 Controller.
After that every modem and usb device works perfectly.
