I’m trying to push a resin image onto a VM running a development download.
The docker/baleine build is failing about half way through with the following message (local paths and hostnames redacted)
$ sudo resin local push xxxxxx.local --source .
Push failed. Error: Error processing tar file(exit status 1): write xxxxxx: no space left on device Error: Error processing tar file(exit status 1): write xxxxx: no space left on device
at Stream. (/snapshot/resin-cli/node_modules/resin-sync/build/docker-utils.js:146:23)
at emitOne (events.js:96:13)
at Stream.emit (events.js:188:7)
at drain (/snapshot/resin-cli/node_modules/through/index.js:36:16)
at Stream.stream.queue.stream.push (/snapshot/resin-cli/node_modules/through/index.js:45:5)
at Parser.exports.parse.parser.onToken (/snapshot/resin-cli/node_modules/JSONStream/index.js:129:18)
at Parser.proto.write (/snapshot/resin-cli/node_modules/jsonparse/jsonparse.js:135:34)
at Stream. (/snapshot/resin-cli/node_modules/JSONStream/index.js:21:12)
at Stream.stream.write (/snapshot/resin-cli/node_modules/through/index.js:26:11)
at IncomingMessage.ondata (_stream_readable.js:555:20)
at IncomingMessage.emit (events.js:188:7)
at readableAddChunk (_stream_readable.js:176:18)
at IncomingMessage.Readable.push (_stream_readable.js:134:10)
at HTTPParser.parserOnBody (_http_common.js:123:22)
at Socket.socketOnData (_http_client.js:363:20)
at Socket.emit (events.js:188:7)
at Socket.Readable.push (_stream_readable.js:134:10)
at TCP.onread (net.js:547:20)
Both the MacOSX host and the target device have more than 1G of free space.
The step that is failing is
Step 36/41 : ADD runtime.tar.gz /
the tar file is about 77MB.
What is the limit I am hitting, and how do I increase it? Or do I need to split up the tar file?
Thanks in advance
Craig
