I’m running a dashboard on a electron-reactjs base.
In the dev environment on my macbook there are no problems. When I run it on the RPI the CSS animations are kind of laggy. I’m changing the background images and the switch between them is pretty slow/low on FPS.
Someone knows what the performance problem could be?
Logs depending the CSS animations (I guess)
main [55:0628/132726.910257:ERROR:bus.cc(399)] Failed to connect to the bus: Failed to connect to socket /run/dbus/system_bus_socket: No such file or directory
main [55:0628/132731.523582:ERROR:bus.cc(399)] Failed to connect to the bus: Failed to connect to socket /run/dbus/system_bus_socket: No such file or directory
main [55:0628/132731.524866:ERROR:bus.cc(399)] Failed to connect to the bus: Failed to connect to socket /run/dbus/system_bus_socket: No such file or directory
main [55:0628/132731.550134:ERROR:bus.cc(399)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
main [55:0628/132731.551817:ERROR:bus.cc(399)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
main
main DevTools listening on ws://127.0.0.1:9222/devtools/browser/2075b59e-b76d-4307-81f0-b821c2c2b952
main [55:0628/132732.098567:ERROR:bus.cc(399)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
main listing on 80
main [55:0628/132732.170750:WARNING:bluez_dbus_manager.cc(247)] Floss manager not present, cannot set Floss enable/disable.
main [91:0628/132733.225186:ERROR:gl_surface_egl.cc(321)] No suitable EGL configs found.
main [91:0628/132733.225877:ERROR:gl_context_egl.cc(140)] eglGetConfigAttrib failed with error EGL_BAD_CONFIG
main [91:0628/132733.226814:ERROR:gl_surface_egl.cc(321)] No suitable EGL configs found.
main [91:0628/132733.227228:ERROR:gl_surface_egl.cc(1110)] eglCreatePbufferSurface failed with error EGL_BAD_CONFIG
main [91:0628/132733.227985:ERROR:gpu_info_collector.cc(80)] gl::GLContext::CreateOffscreenGLSurface failed
main [91:0628/132733.228970:ERROR:gpu_info_collector.cc(401)] Could not create surface for info collection.
main [91:0628/132733.229935:ERROR:gpu_init.cc(88)] CollectGraphicsInfo failed.
main [91:0628/132733.296882:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
main [134:0628/132733.492938:WARNING:sandbox_linux.cc(393)] InitializeSandbox() called with multiple threads in process gpu-process.
main [134:0628/132733.597606:ERROR:gpu_memory_buffer_support_x11.cc(49)] dri3 extension not supported.
main [55:0628/132734.547597:INFO:CONSOLE(2)] "react-index loading", source: file:///usr/src/app/build/static/js/main.cdcde399.js (2)
Plus: I would like to inspect the electron and react instance on the RPI. I activated the remote dev tools, but I can’t connect to it. If someone knows how to remote debug it, please let me know.
Informations to the remote debugging problem:
When the container starting it even says “DevTools listening on ws://127.0.0.1:9222/devtools/browser/453890f6-779b-405a-a5d7-508a698a89e7” in the logs.
dockerfile:
FROM balenalib/%%BALENA_MACHINE_NAME%%-node:14.17-bullseye-build as build
# Install other apt deps
apt-utils \
# Set Xorg and FLUXBOX preferences
RUN mkdir ~/.fluxbox
RUN echo "xset s off" > ~/.fluxbox/startup && echo "xserver-command=X -s 0 dpms" >> ~/.fluxbox/startup
RUN echo "#!/bin/bash" > /etc/X11/xinit/xserverrc \
&& echo "" >> /etc/X11/xinit/xserverrc \
&& echo 'exec /usr/bin/X -s 0 dpms -nocursor -nolisten tcp "$@"' >> /etc/X11/xinit/xserverrc
# Move to app dir
WORKDIR /usr/src/app
# Move package.json to filesystem
COPY ./app/package.json ./
# Install npm modules for the application
# Install dev deps so we can build app
RUN JOBS=MAX npm install --unsafe-perm \
&& npm cache verify && node_modules/.bin/electron-rebuild
# Move app to filesystem
COPY ./app ./
# Build react app
RUN JOBS=MAX npm run build
## uncomment if you want systemd
ENV INITSYSTEM on
# Expose the debugging port
EXPOSE 9222
# Start app
CMD ["bash", "/usr/src/app/start.sh"]
start.sh
#!/bin/bash
export URL_LAUNCHER_NODE=1
export NODE_ENV=production
# By default docker gives us 64MB of shared memory size but to display heavy
# pages we need more.
umount /dev/shm && mount -t tmpfs shm /dev/shm
# using local electron module instead of the global electron lets you
# easily control specific version dependency between your app and electron itself.
# the syntax below starts an X istance with ONLY our electronJS fired up,
# it saves you a LOT of resources avoiding full-desktops envs
rm /tmp/.X0-lock &>/dev/null || true
startx /usr/src/app/node_modules/electron/dist/electron /usr/src/app --no-sandbox --enable-logging --remote-debugging-port=9222
main.js
app.commandLine.appendSwitch("remote-debugging-port", "9222");
// enable touch events if your device supports them
if (electronConfig.URL_LAUNCHER_TOUCH) {
app.commandLine.appendSwitch("--touch-devices");
SUPERVISOR VERSION: 14.11.2
HOST OS VERSION: balenaOS 2.113.18
