We’re trying to build an application for an AARCH64 device. As we have no possibility to flash BalenaOS on the device, we decided to run BalenaOS in Docker, with the generic AARCH64 option available in BalenaCloud.
We managed to do the setup correctly, I think, as all our containers are automatically deployed to BalenaOS and are started. However, one of our containers fails to run. This container makes use of DBus and if we check the logs of that container, the following error is shown:
(node:33) UnhandledPromiseRejectionWarning: Error initializing network manager: Error: Failed to connect to socket /host/run/dbus/system_bus_socket: No such file or directory
(Use node --trace-warnings ...
to show where the warning was created)
(node:33) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict
(see Command-line options | Node.js v15.9.0 Documentation). (rejection id: 2)
(node:33) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
As you can see, the container can’t access the dbus system bus socket on the host container, eventhough it’s there. We found that this behavior happens if the dbus label is not provided in the docker-compose file, however we did add this label. This is part of our docker-compose file:
environment:
DBUS_SYSTEM_BUS_ADDRESS=unix:path=/host/run/dbus/system_bus_socket
labels:
io.balena.features.dbus: ‘1’
I’m not sure how to continue to get this container working in Balena. Do you have any idea what we’re doing wrong or what we have to do to fix this issue?
Thanks in advance for the help.
