Is it possible to bootstrap Balena OS onto a new ARM board? say the Rock64 4gb?
Have a look at the following pages, which have an overview of how to add support for a new board:
- https://www.balena.io/docs/reference/OS/meta-balena/
- https://www.balena.io/os/docs/custom-build/#supporting-your-own-board
Also for reference, you can check the repos of other supported boards, like the Raspberry Pi:
If it is of interest and depending on the details, Balena may also be able to offer a custom hardware support package (a paid service). Check the sales contact details at the top of this page:
Let us know how you get on with it – we can help you further according to the direction you choose to go.
Hey @codefriar,
Did you ever get anywhere with the Rock64. I am beginning to explore using it for our project.
-Thomas
I’m also interested in the Rock64.
@tacLog and @codefriar I found https://github.com/trecetp/meta-rock64 which is the BSP for the Rock64.
I was able to run a BitBake build for core-image-base, but there’s no SD Image, so you need to partition it manually and place kernel, dtb and roofs in the right place. Maybe with balenaOS things could be different, but I haven’t tried much in that regard.
Hey @bernardoaraujor
We went with the Odroid xu4. Good luck with the rock64, I found it got way too warm for out application. I only ever tested it with Ubuntu, but I don’t think that would change anything.
Best of luck to you,
-Thomas
hi @tacLog thanks for your reply.
I was able to get in touch with the creator of meta-rock64.
We are collaborating and I think I will be able to submit a PR with a sdimage.bbclass to the layer soon.
Perhaps you should do your tests with balenaOS instead of Ubuntu. Ubuntu has a lot of bloatware and could be wasting some CPU power and causing the overheating.
