Is it possible to migrate away from balenaOS, on a hot-balenaOS instance?
Hi all,
First of all, please do remove the topic if you’re not happy about it. I fully understand that, if that’s the case. I am not here trying to damage the balenaOS or the Balena Company in any way. I enjoy using the product.
I have a few devices running balenaOS, where the features from the balenaOS and Cloud, are no longer a requirement. But they’re on remote locations, so I don’t have an option to simply swap out the SD card with a fresh linux distro and a remote tunnel, or similar.
Are there a way to migrate to another distro, or strip the parts I don’t need in the balenaOS, while still keeping a remote connection? I know there’s plenty of products to solve that, but I’m not here to talk about the alternatives (!).
I know it sounds a bit crazy. But it’s not 100% un-common to hot migrate from one distro to another, in rare scenarios (CentOS to alternative, and similar cases - i know they’re not comparable in the same way).
I’ve seen a guide to migrate to Open Balena, but that’s not enought. I still need to be able to connect to the host instance, so I’m able to setup a remote connection, to be used in the future.
In short: I’m looking for suggestions, on how to migrate to another distro, or strip down the Balena-related things, from the balenaOS, so I don’t have to keep them in the Balena Cloud.
By looking around, I’ve not been able to find anyone talking about a migration like that.
Currently I can only think about one solution: Preparing a SD card image, and get a person “on location” to handle a flash. But that doesn’t match, what I’m hoping to do, one way or another, but done remotely.
I know there’s risk involved.
If you have any experince with this, I’m ready to take your suggestions and inputs. Also alternative solutions, if there’s any.
It’s not easy to migrate from balenaOS to another distro remotely, as balenaOS is tightly integrated with Balena Cloud services. However, one option is to strip down unnecessary components, leaving only the base OS and necessary services. You could use Docker or similar containerization tools to maintain the remote connection while removing Balena-specific parts.
Hey @exetico it’s possible, Balena has migration products that do the opposite, that is, migrate from another OS like Debian or RaspberryPi OS, to balenaOS.
We also use the remote migrator to migrate between balenaOS variants, like when partition changes are required.
However, as you may understand, we haven’t spent time developing that product to migrate away from balenaOS.
Hi @exetico I also have the requirement that some customers might not want their devices connected to the (Balena)Cloud. We are planning for the devices to deactivate themselves using the CLI. This is a paying feature though.
@alexgg Is there a way for devices to reactivate themselves?
Devices will reactivate when the come back online. See Billing | balena
