we are using Resin OS 2.12.7+rev1(prod) on a Siemens IOT2040 that has two ethernet interfaces.
In our configuration:
- The eth0 (that in IOT has name enp0s20f6) has the default configuration (DHCP) and provides internet access
- The eth1 (that in IOT has name enp0s20f7) has a Static IP
In the dashboard I can see the device online and I can use the terminal, but the logs are not updated and other commands like “Restart” report errors like
Request error: tunneling socket could not be established, cause=socket hang up
; also detaching the Ethernet cable from eth1 the problem remains.
Using balena attach I can see the output of the container that are running correctly.
Before setting up the static IP on the second interface the logs worked correctly.
Hello, it appears the Supervisor is unresponsive. What is the output of balena ps -a and journalctl -fn100 -u resin-supervisor?
Hi @dfunckt,
balena ps -a output is this:
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
aa4bab436931 65ff27feddcb "/usr/bin/entry.sh..." 6 days ago Up 19 hours 0.0.0.0:8080->80/tcp dashboard_310365_506685
e9822e7b9c21 e56995d0637d "/usr/bin/entry.sh..." 6 days ago Up 19 hours 0.0.0.0:3000->3000/tcp, 0.0.0.0:8081->8080/tcp observer_310363_506685
f32028d2293d c56313ecf01a "/docker-entrypoin..." 9 days ago Up 19 hours 0.0.0.0:80->80/tcp, 0.0.0.0:9090->9090/tcp proxy_310364_506685
a38fb5859570 resin/i386-nlp-supervisor:v7.4.3 "./entry.sh" 9 days ago Exited (255) 19 hours ago resin_supervisor
and it seems that the supervisor has exited and not restarted again.
The output of journalctl -fn100 -u resin-supervisor is only this:
– Logs begin at Thu 2018-06-07 07:02:36 UTC. –
Hmm, weird that it hasn’t come back up and that there’s no logs. Can you see whether systemctl start resin-supervisor brings the supervisor up? That should do it for now, but this might need further investigation on why this happened
After running systemctl start resin-supervisor the output of balena ps -a is equal to
aa4bab436931 65ff27feddcb "/usr/bin/entry.sh..." 6 days ago Up 21 hours 0.0.0.0:8080->80/tcp dashboard_310365_506685
e9822e7b9c21 e56995d0637d "/usr/bin/entry.sh..." 6 days ago Up 21 hours 0.0.0.0:3000->3000/tcp, 0.0.0.0:8081->8080/tcp observer_310363_506685
f32028d2293d c56313ecf01a "/docker-entrypoin..." 9 days ago Up 21 hours 0.0.0.0:80->80/tcp, 0.0.0.0:9090->9090/tcp proxy_310364_506685
a38fb5859570 resin/i386-nlp-supervisor:v7.4.3 "./entry.sh" 9 days ago Up 35 seconds (health: starting)
but the log doesn’t update. It seems like the supervisor container restarts every 1-2 minutes.
That’s quite strange, would it be possible to provide us with a device that can connect to and investigate a bit?
How did you set up the static IP on the device?
After a while, the device started working again; have I to “grant support access” in order to let you investigate on the device?
I have set the static IP following the tutorial on the resin.io website: https://docs.resin.io/reference/resinOS/network/2.x/#setting-a-static-ip.
