I’m working on the project below in a container:
docker-compose:
version: '2'
services:
system:
build: ./system
restart: always
privileged: true
labels:
io.balena.features.dbus: '1'
io.balena.features.firmware: '1'
io.balena.features.kernel-modules: '1'
docker.template:
# base-image for python on any machine using a template variable,
# see more about dockerfile templates here:http://docs.resin.io/pages/deployment/docker-templates
FROM resin/%%RESIN_MACHINE_NAME%%-python
# use apt-get if you need to install dependencies
RUN apt-get update && apt-get install -yq \
python-smbus && \
# Set our working directory
WORKDIR /usr/src/app
# Copy requirements.txt first for better cache on later pushes
COPY ./requirements.txt /requirements.txt
# pip install python deps from requirements.txt on the resin.io build server
#RUN pip install -r /requirements.txt
# This will copy all files in our root to the working directory in the container
COPY . ./
# switch on systemd init system in container
ENV INITSYSTEM on
# start.sh will run when container starts up on the device
CMD ["bash", "start.sh"]
start.sh:
#/bin/bash
# Strips device-type from hostname (only works on resin.io base images)
DEVICE_TYPE=${HOSTNAME%-*}
I2C_BUS=0 # Default i2c bus number
# Enables i2c for the platform and set the appropriate bus number.
if [[ "$DEVICE_TYPE" =~ "raspberrypi" ]]; then
modprobe i2c-dev
export I2C_BUS=1
elif [[ "$DEVICE_TYPE" = "odroid-c1" ]]; then
modprobe i2c-dev
modprobe aml_i2c
export I2C_BUS=1
elif [[ "$DEVICE_TYPE" = "beaglebone" ]]; then
# i2c0: Not exposed in the expansion headers
# i2c1: pins P9 17,18 (and 24,26)
# i2c2: pins P9 19,20 (and 21,22)
# load cape-universaln if you need i2c-1
#echo cape-universaln > /sys/devices/platform/bone_capemgr/slots
export I2C_BUS=2
elif [[ "$DEVICE_TYPE" = "artik5" ]]; then
# Currently not working :/
export I2C_BUS=9
elif [[ "$DEVICE_TYPE" = "artik10" ]]; then
export I2C_BUS=7
else
echo "Unable to detect device type!!!"
fi
echo "detected $DEVICE_TYPE"
#Starts our sensor read script.
python src/sensor.py
And the python script is:
import smbus, os
from time import sleep
busNumber = int(os.getenv("I2C_BUS"))
bus = smbus.SMBus(busNumber)
# ADXL345 constants
EARTH_GRAVITY_MS2 = 9.80665
SCALE_MULTIPLIER = 0.004
DATA_FORMAT = 0x31
BW_RATE = 0x2C
POWER_CTL = 0x2D
BW_RATE_1600HZ = 0x0F
BW_RATE_800HZ = 0x0E
BW_RATE_400HZ = 0x0D
BW_RATE_200HZ = 0x0C
BW_RATE_100HZ = 0x0B
BW_RATE_50HZ = 0x0A
BW_RATE_25HZ = 0x09
RANGE_2G = 0x00
RANGE_4G = 0x01
RANGE_8G = 0x02
RANGE_16G = 0x03
MEASURE = 0x08
AXES_DATA = 0x32
class ADXL345:
address = None
def __init__(self, address = 0x53):
self.address = address
self.setBandwidthRate(BW_RATE_100HZ)
self.setRange(RANGE_2G)
self.enableMeasurement()
def enableMeasurement(self):
bus.write_byte_data(self.address, POWER_CTL, MEASURE)
def setBandwidthRate(self, rate_flag):
bus.write_byte_data(self.address, BW_RATE, rate_flag)
# set the measurement range for 10-bit readings
def setRange(self, range_flag):
value = bus.read_byte_data(self.address, DATA_FORMAT)
value &= ~0x0F
value |= range_flag
value |= 0x08
bus.write_byte_data(self.address, DATA_FORMAT, value)
# returns the current reading from the sensor for each axis
# parameter gforce:
# False (default): result is returned in m/s^2
# True : result is returned in gs
def getAxes(self, gforce = False):
bytes = bus.read_i2c_block_data(self.address, AXES_DATA, 6)
x = bytes[0] | (bytes[1] << 8)
if(x & (1 << 16 - 1)):
x = x - (1<<16)
y = bytes[2] | (bytes[3] << 8)
if(y & (1 << 16 - 1)):
y = y - (1<<16)
z = bytes[4] | (bytes[5] << 8)
if(z & (1 << 16 - 1)):
z = z - (1<<16)
x = x * SCALE_MULTIPLIER
y = y * SCALE_MULTIPLIER
z = z * SCALE_MULTIPLIER
if gforce == False:
x = x * EARTH_GRAVITY_MS2
y = y * EARTH_GRAVITY_MS2
z = z * EARTH_GRAVITY_MS2
x = round(x, 4)
y = round(y, 4)
z = round(z, 4)
return {"x": x, "y": y, "z": z}
if __name__ == "__main__":
# if run directly we'll just create an instance of the class and output
# the current readings
adxl345 = ADXL345()
while False:
axes = adxl345.getAxes(True)
print "ADXL345 on address 0x%x:" % (adxl345.address)
print " x = %.3fG" % ( axes['x'] )
print " y = %.3fG" % ( axes['y'] )
print " z = %.3fG" % ( axes['z'] )
sleep(5)
I can’t figure out what I’m doing wrong here. The log I get is this:
02.11.19 12:59:36 (-0700) system detected raspberrypi3
02.11.19 12:59:36 (-0700) system Traceback (most recent call last):
02.11.19 12:59:36 (-0700) system File "src/sensor.py", line 6, in <module>
02.11.19 12:59:36 (-0700) system bus = smbus.SMBus(busNumber)
02.11.19 12:59:36 (-0700) system IOError: [Errno 2] No such file or directory
So essentially the error is IOError. This is listed as something that happens in this project:
Which tells you to restart the service and that it’s normal the first time:
However restarting the service doesn’t seem to help.
