Inconsistent hostname when set via host-config supervisor API endpoint
Use case:
Set a persistent hostname of a resin device.
Issue:
Before change the hostname was as follows:
Device hostname: 05d447f
Container hostname: 05d447f
Using starter application.
Using Resin OS 2.13.6+rev1 development
Using 7.14.0
I read through Read-only file-system when calling SetStaticHostname via dbus - #2 by exposedwiring and decided to go for the host-config supervisor API endpoint.
I used the following command called from the container:
curl -X PATCH --header “Content-Type:application/json”
–data ‘{“network”: {“hostname”: “whee”}}’
“$RESIN_SUPERVISOR_ADDRESS/v1/device/host-config?apikey=$RESIN_SUPERVISOR_API_KEY”
After reboot the hostname was as follows:
Device hostname: whee
Container hostname: intel-nuc-05d447f
Content of the /resin-boot/config.json:
{ “deviceType”: “intel-nuc”, “hostname”:“resin”, “persistentLogging”: “false” }
Note I did not change the config.json file manually.
I am unsure if this as expected?
I would assume the same hostname on both device and the running container. This is also supported by resinOS 2.0 released in production. A section states:
If you use resin.io base images, you will notice that the hostname has changed from <device_type>-<short_uuid> to just <short_uuid> , however, if you set a customised hostname in your config.json, that will also be reflected in the container hostname.
Based on the above I would expect the following:
Device hostname: resin
Container hostname: resin
But for some reason the config.json is ignored and i get:
Seems that host-config API endpoint overrule what ever is stated in config.json, but is not consistently applied in the container hostname.
Tried the same on a production resin device.
Result is as follows:
Container hostname: 86d162d
Is this as expected?
After a resin service update the hostname changed to:
Container hostname: intel-nuc-86d162d
The hostname is inconsistent
