Before you all read this I can’t stress enough not all of these are issues.
Some of the findings on this list just need to be verified. Some of the logs will include a statement “While this is not, in and of itself, a bug, you should manually inspect these directories to ensure that they are in compliance with company security standards” & “If you think any of this information is wrong please report it to the referenced community portal.”
These messages were generated by openvas so please do not take everything here at face value.
However, there is a reference to CVE-1999-05 ICMP Timestamp Detection, so no one should get too excited over this, panic or stop using the service. I’m not stopping because I love what these people do and as a contributor that enjoys using the product providing feedback.
Also the IP has been replaced with xxx.xxx.xxx.xxx some other info has been edited out.
general/icmp
Summary
The remote host responded to an ICMP timestamp request. The Timestamp Reply is an ICMP message which replies to a Timestamp message. It consists of the originating timestamp sent by the sender of the Timestamp as well as a receive timestamp and a transmit timestamp. This information could theoretically be used to exploit weak time-based random number generators in other services.
Vulnerability Detection Result
Vulnerability was detected according to the Vulnerability Detection Method.
Log Method
Details: ICMP Timestamp Detection (OID: 1.3.6.1.4.1.25623.1.0.103190)
Version used: Revision: 10411
References
CVE: CVE-1999-0524
CERT: CB-K15/1514, CB-K14/0632, DFN-CERT-2014-0658
Other: http://www.ietf.org/rfc/rfc0792.txt
CGI Scanning Consolidation
2375/tcp
Summary
The script consolidates various information for CGI scanning.
This information is based on the following scripts / settings:
- HTTP-Version Detection (OID: 1.3.6.1.4.1.25623.1.0.100034)
- No 404 check (OID: 1.3.6.1.4.1.25623.1.0.10386)
- Web mirroring / webmirror.nasl (OID: 1.3.6.1.4.1.25623.1.0.10662)
- Directory Scanner / DDI_Directory_Scanner.nasl (OID: 1.3.6.1.4.1.25623.1.0.11032)
- The configured ‘cgi_path’ within the ‘Scanner Preferences’ of the scan config in use
- The configured ‘Enable CGI scanning’, ‘Enable generic web application scanning’ and ‘Add historic /scripts and /cgi-bin to directories for CGI scanning’ within the ‘Global variable settings’ of the scan config in use
The Hostname/IP “” was used to access the remote host.
Generic web application scanning is disabled for this host via the “Enable generic web application scanning” option within the “Global variable settings” of the scan config in use.
Requests to this service are done via HTTP/1.1.
This service seems to be able to host PHP scripts.
This service seems to be able to host ASP scripts.
The User-Agent “Mozilla/5.0 [en] (X11, U; OpenVAS-VT 9.0.3)” was used to access the remote host.
Historic /scripts and /cgi-bin are not added to the directories used for CGI scanning. You can enable this again with the “Add historic /scripts and /cgi-bin to directories for CGI scanning” option within the “Global variable settings” of the scan config in use.
The following directories were used for CGI scanning:
http://:2375/
Log Method
Details: CGI Scanning Consolidation (OID: 1.3.6.1.4.1.25623.1.0.111038)
Version used: Revision: 13679
80/tcp
Summary
http:///
http:///login
http:///public/build
The following directories were excluded from CGI scanning because the “Regex pattern to exclude directories from CGI scanning” setting of the NVT “Global variable settings” (OID: 1.3.6.1.4.1.25623.1.0.12288) for this scan was: “/(index.php|image|img|css|js$|js/|javascript|style|theme|icon|jquery|graphic|grafik|picture|bilder|thumbnail|media/|skins?/)”
http:///public/img
Log Method
CPE Inventory
general/CPE-T
Summary
This routine uses information collected by other routines about CPE identities of operating systems, services and applications detected during the scan.
xxx.xxx.xxx.xxx|cpe:/a:docker:docker:17.13.3-dev
xxx.xxx.xxx.xxx|cpe:/a:_:dropbear_ssh_server:2017.75
xxx.xxx.xxx.xxx|cpe:/o:linux:kernel
Log Method
Details: CPE Inventory (OID: 1.3.6.1.4.1.25623.1.0.810002)
Version used: Revision: 14324
DIRB (NASL wrapper)
2375/tcp
Summary
This script uses DIRB to find directories and files on web applications via brute forcing. See the preferences section for configuration options.
Note: The plugin needs the ‘dirb’ binary found within the PATH of the user running the scanner and needs to be executable for this user. The existence of this binary is checked and reported separately within ‘Availability of scanner helper tools’ (OID: 1.3.6.1.4.1.25623.1.0.810000).
This are the directories/files found with brute force:
http://:2375/
Log Method
Details: DIRB (NASL wrapper) (OID: 1.3.6.1.4.1.25623.1.0.103079)
Version used: Revision: 13985
DIRB (NASL wrapper)
80/tcp
Summary
http://:2375/
http://:80/
Log Method
Docker Detection
2375/tcp
Summary
The script sends a connection request to the server and attempts to extract the version number from the reply.
Detected Docker
Version: 17.13.3-dev (ApiVersion: 1.35)
CPE: cpe:/a:docker:docker:17.13.3-dev
Concluded from version/product identification result:
Version":“17.13.3-dev”,
Concluded from version/product identification location:
/version
The following containers where detected running on the remote host:
Image sha256:f7e1b3e3dca838fe1448e3bb6b93e3a80abece9ed8ee81c124866f7154e5c720
Ports: N/A
Image sha256:cbe1b4f2af15446b9fe1be4ed148c14d9e7e3ce465aa4e53ae77c42f62f8aff0
Ports: 0.0.0.0:80->80/tcp,
Image sha256:45dc3eed9ee66b75c6138b2f423d7ffb16d5f129689f7c7275ae01390895ec0f
Ports: N/A
Image sha256:e2456354b82667050471f47fb446e359040469cab3d816b09bbc39df2b59bc2f
Ports: N/A
Image balena/rpi-supervisor:v9.14.0
Ports: N/A
Dropbear SSH Detection
22222/tcp
Summary
Detected Dropbear
Version: 2017.75
CPE: cpe:/a:_:dropbear_ssh_server:2017.75
SSH-2.0-dropbear_2017.75
Log Method
Details: Dropbear SSH Detection (OID: 1.3.6.1.4.1.25623.1.0.105112)
Version used: Revision: 13576
HTTP Security Headers Detection
80/tcp
Summary
All known security headers are being checked on the host. On completion a report will hand back whether a specific security header has been implemented (including its value) or is missing on the target.
Header Name Header Value
X-Frame-Options : deny
Missing Headers
Content-Security-Policy
Referrer-Policy
X-Content-Type-Options
X-Permitted-Cross-Domain-Policies
X-XSS-Protection
Log Method
Details: HTTP Security Headers Detection (OID: 1.3.6.1.4.1.25623.1.0.112081)
Version used: Revision: 10899
Nikto (NASL wrapper)
2375/tcp
Summary
This plugin uses nikto to find weak CGI scripts and other known issues regarding web server security. See the preferences section for configuration options.
Note: The plugin needs the ‘nikto’ or ‘nikto.pl’ binary found within the PATH of the user running the scanner and needs to be executable for this user. The existence of this binary is checked and reported separately within ‘Availability of scanner helper tools’ (OID: 1.3.6.1.4.1.25623.1.0.810000).
Here is the Nikto report:
- Target IP: xxx.xxx.xxx.xxx
- Target Hostname: xxx.xxx.xxx.xxx
- Target Port: 2375
- Virtual Host:
- Start Time: 2019-07-27 12:21:22 (GMT0)
- Server: No banner retrieved
- The anti-clickjacking X-Frame-Options header is not present.
- The X-XSS-Protection header is not defined. This header can hint to the user agent to protect against some forms of XSS
- The X-Content-Type-Options header is not set. This could allow the user agent to render the content of the site in a different fashion to the MIME type
- No CGI Directories found (use ‘-C all’ to force check all possible dirs)
- Server banner has changed from ‘’ to ‘Docker/17.13.3-dev (linux)’ which may suggest a WAF, load balancer or proxy is in place
- Uncommon header ‘api-version’ found, with contents: 1.35
- Uncommon header ‘docker-experimental’ found, with contents: true
- Uncommon header ‘ostype’ found, with contents: linux
- 7942 requests: 0 error(s) and 6 item(s) reported on remote host
- End Time: 2019-07-27 12:24:26 (GMT0) (184 seconds)
- 1 host(s) tested
Log Method
Details: Nikto (NASL wrapper) (OID: 1.3.6.1.4.1.25623.1.0.14260)
OS Detection Consolidation and Reporting
general/tcp
Summary
This script consolidates the OS information detected by several NVTs and tries to find the best matching OS.
Furthermore it reports all previously collected information leading to this best matching OS. It also reports possible additional information which might help to improve the OS detection.
If any of this information is wrong or could be improved please consider to report these to the referenced community portal.
Best matching OS:
OS: Linux/Unix
CPE: cpe:/o:linux:kernel
Found by NVT: 1.3.6.1.4.1.25623.1.0.105112 (Dropbear SSH Detection)
Setting key “Host/runs_unixoide” based on this information
Log Method
Details: OS Detection Consolidation and Reporting (OID: 1.3.6.1.4.1.25623.1.0.105937)
Version used: 2019-07-22T05:49:21+0000
References
Other: https://community.greenbone.net/c/vulnerability-tests
robot(s).txt exists on the Web Server
80/tcp
Summary
Web Servers can use a file called /robot(s).txt to ask search engines to ignore certain files and directories. By nature this file can not be used to protect private files from public read access.
The file ‘robots.txt’ contains the following:
User-agent: *
Disallow: /
Solution
Solution type: Mitigation
Review the content of the robots file and consider removing the files from the server or protect them in other ways in case you actually intended non-public availability.
Vulnerability Insight
Any serious web search engine will honor the /robot(s).txt file and not scan the files and directories listed there.
Any entries listed in this file are not even hidden anymore.
Log Method
Details: robot(s).txt exists on the Web Server (OID: 1.3.6.1.4.1.25623.1.0.10302)
SSH Protocol Algorithms Supported
22222/tcp
Summary
This script detects which algorithms and languages are supported by the remote SSH Service
The following options are supported by the remote ssh service:
kex_algorithms:
curve25519-sha256@libssh.org,ecdh-sha2-nistp521,ecdh-sha2-nistp384,ecdh-sha2-nistp256,diffie-hellman-group14-sha1,kexguess2@.ucc.asn.au
server_host_key_algorithms:
ssh-rsa
encryption_algorithms_client_to_server:
aes128-ctr,aes256-ctr
encryption_algorithms_server_to_client:
mac_algorithms_client_to_server:
hmac-sha1,hmac-sha2-256,hmac-sha2-512,hmac-md5
mac_algorithms_server_to_client:
compression_algorithms_client_to_server:
zlib@openssh.com,none
compression_algorithms_server_to_client:
Log Method
Details: SSH Protocol Algorithms Supported (OID: 1.3.6.1.4.1.25623.1.0.105565)
Version used: Revision: 13581
