Hi!
I try to change some things in balena-cam service and therefore I work in local mode.
I can push with sudo balena push IP and even the service is running (can see the cam output in browser) but no logging messages with console.log from client.js are visible.
Not with balena logs IP nor with “Streaming device logs…” from push command.
Do I need something else to see the message from client.js?
Thank you!
