djsmal
October 23, 2023, 8:21am
1
There is a new API fix but I don’t fully understand how to use it.
In https://github.com/balena-io/open-balena-api/blob/9fd9697f37423c891aea9faa92e45a9ca0db2137/src/lib/config.ts#L87C48-L87C48 the comment mentions
* null: include all device type and device contract slugs
* "x;y;z": include only the specified device type and contract slugs - note that you MUST list
* all dependent slugs as well so for hw.device-type/asus-tinker-board-s you would need:
* `arch.sw/armv7hf;hw.device-manufacturer/asus;hw.device-family/tinkerboard;hw.device-type/asus-tinker-board-s`
* For something like hw.device-type/iot-gate-imx8 you would need:
* `arch.sw/aarch64;hw.device-type/iot-gate-imx8`
* (the order of the slugs in this variable does not matter)
How does one figure out all dependent slugs given device type?
For example, we use:
raspberrypi4-64
raspberrypi3
asus-tinker-board
asus-tinker-board-s
What should CONTRACT_ALLOWLIST look like?
djsmal
October 23, 2023, 12:06pm
2
My best guess is that in our case CONTRACT_ALLOWLIST should look like this:
export OPENBALENA_CONTRACT_ALLOWLIST="arch.sw/armv7hf;arch.sw/aarch64;hw.device-manufacturer/asus;hw.device-family/tinkerboard;hw.device-type/asus-tinker-board-s;hw.device-type/asus-tinker-board;hw.device-type/raspberrypi3;hw.device-type/raspberrypi4-64;sw.os+hw.device-type/ubuntu@lunar+raspberrypi3;sw.os+hw.device-type/ubuntu@jammy+raspberrypi3;sw.os+hw.device-type/alpine+raspberrypi3;sw.os+hw.device-type/debian@sid+raspberrypi3;sw.os+hw.device-type/debian+raspberrypi3;sw.os+hw.device-type/ubuntu@focal+raspberrypi3;sw.os+hw.device-type/ubuntu@focal+raspberrypi4-64;sw.os+hw.device-type/debian@sid+raspberrypi4-64;sw.os+hw.device-type/alpine+raspberrypi4-64;sw.os+hw.device-type/debian+raspberrypi4-64;sw.os+hw.device-type/ubuntu@lunar+raspberrypi4-64;sw.os+hw.device-type/ubuntu@jammy+raspberrypi4-64;sw.os+hw.device-type/debian@bookworm+raspberrypi4-64"
Here is the same but with an explanation of why it’s there.
arch.sw/armv7hf; # asus-tinker-board, asus-tinker-board-s, raspberrypi3
arch.sw/aarch64; # raspberrypi4-64
hw.device-manufacturer/asus; # asus-tinker-board, asus-tinker-board-s
hw.device-family/tinkerboard; # asus-tinker-board, asus-tinker-board-s
hw.device-type/asus-tinker-board-s; # asus-tinker-board-s
hw.device-type/asus-tinker-board; # asus-tinker-board
hw.device-type/raspberrypi3; # raspberrypi3
hw.device-type/raspberrypi4-64; # raspberrypi4-64
sw.os+hw.device-type/ubuntu@lunar+raspberrypi3; # raspberrypi3
sw.os+hw.device-type/ubuntu@jammy+raspberrypi3; # raspberrypi3
sw.os+hw.device-type/alpine+raspberrypi3; # raspberrypi3
sw.os+hw.device-type/debian@sid+raspberrypi3; # raspberrypi3
sw.os+hw.device-type/debian+raspberrypi3; # raspberrypi3
sw.os+hw.device-type/ubuntu@focal+raspberrypi3; # raspberrypi3
sw.os+hw.device-type/ubuntu@focal+raspberrypi4-64; # raspberrypi4-64
sw.os+hw.device-type/debian@sid+raspberrypi4-64; # raspberrypi4-64
sw.os+hw.device-type/alpine+raspberrypi4-64; # raspberrypi4-64
sw.os+hw.device-type/debian+raspberrypi4-64; # raspberrypi4-64
sw.os+hw.device-type/ubuntu@lunar+raspberrypi4-64; # raspberrypi4-64
sw.os+hw.device-type/ubuntu@jammy+raspberrypi4-64; # raspberrypi4-64
sw.os+hw.device-type/debian@bookworm+raspberrypi4-64 # raspberrypi4-64
I got this from GitHub - balena-io/contracts: Balena.io Base Contracts .
If anybody can confirm that this is right or correct it if it is wrong that would be great
scscsc
December 23, 2023, 1:41am
3
I believe I replied to you on github here (similar username), but I figured I’d add the notes here in case anyone else is only checking the forums and not GitHub:
I would suggest looking through contracts/contracts at master · balena-io/contracts · GitHub
For example, start with hw.device-type/raspberrypi3/contract.json and you’ll see it references "arch": "armv7hf" on line 14, so for this you’d need:
arch.sw/armv7hf
Doing the same for hw.device-type/raspberrypi4-64/contract.json gets you:
arch.sw/aarch64
And for Doing the same for hw.device-type/asus-tinker-board-s/contract.json gets you’ll see both "arch": "armv7hf" and "family": "family-tinkerboard", so you need:
arch.sw/armv7hf
… but if you check hw.device-family/tinkerboard/contract.json you’ll see that it references "manufacturedBy": "manufacturer-asus" on line 8, so you also need:
hw.device-manufacturer/asus (which is the contract.json with a slug of “manufacturer-asus” as referenced in the family contract)
If you don’t know in advance what you want in there, just don’t set OPENBALENA_CONTRACT_ALLOWLIST and open-balena will continue to pull down everything like it did before the change.
