Most docker images use config files mounted from the host which doesn’t work with the balena workflow and using a compose file.
I am trying to come up with a way to create files from an env variable so that these can be used when starting a docker image. This will allow to use upstream images and not keep any config in the docker image itself making those more universal and provide new configs at runtime.
For example:
config_env = “some config text” - env var set in the balena GUI
start a docker container like docker run prometheus/prometheus --config.file=$(echo $config_env > /env_files/config_env && echo /env_files/config_env
I am not sure if this would work , but will test it shortly.
Do you think it would be possible to have this as part of balena os/cli? when you have an env var as config_env you can directly use it as a file /env_files/config_env
