I installed Wifi Connect on my raspberry pi Zero W using the instructions found on the github page. After following the installation instructions, when I run wifi connect with “sudo wifi-connect” and access point is successfully created but I get an error:
Error: Cannot start HTTP server on ‘192.168.42.1:80’: address in use
dnsmasq: failed to create listening socket for 192.168.42.1: Address already in use.
Can you describe a little more about what you are running wifi-connect on? Is this a balenaOS device, or Raspbian/Debian/some other linux flavor? Are you running other containers locally?
Hi! thank you so much for the response. I am running wifi-connect on a raspberry pi zero W with the raspbian OS with no other additional conatiners or anything to my knowledge. My project is a python datalogger that receives data via RF and stores it in a database. I am not running any of this project while trying to get wifi-connect to work. To install wifi-connect I ran the following command
Hey, that error is coming from something else on your raspbian os listening on port 80, you can probably run netstat -l to list the ports that processes are listening on and then you’ll need to stop whichever process is using port 80 - probably either apache or nginx that you’ve installed on raspbian
ahhh yes, that would make sense. Thank you! do you know if it is possible to run wifi-connect on a port other than 80? and would I need to change anything on my smartphone end?
Thanks for all of the help so far. I have tried changing the port number which got rid of the error message that I was getting. However, I still get the message “dnsmasq: failed to create listening socket for ~whatever ip i put in~: Address already in use”
The default is 192.168.42.1
I have tried: 192.168.2.20, 192.168.1.11, 1.1.1.1, 192.168.0.0 and a few others and everything gives me the same message. Any ideas?
nmcli at 1.6.2 means that you are running Raspbian Stretch, so this should be fine.
Can you try the following - install wifi-connect first on a freshly flashed Raspbian? Try out how it is working for you. And afterwards install the additional software you are using and try again. It looks like the OS on the device is not working as expected, so this is why I suggest installing things from scratch.
I get the same error. After a few hours, I do not see a solution.
(.venv) pi@picroft:~ $ sudo wifi-connect
Deleting already created by WiFi Connect access point connection profile: “WiFi Connect”
WiFi device: wlan0
Access points: [“QBPDC”]
Starting access point…
Access point ‘WiFi Connect’ created
Starting HTTP server on 192.168.42.1:80
