yes I’m a noob’s noob! I just signed up for belena cloud and can’t get passed step 2 of the sign up process. I’m using a windows 7 home premium desktop to get started. the SSH Key step is kicking my tail. I’ve tried following the instructions using a command prompt window but all I get is an error message. I know that the Raspberry Pi runs a subset of linux and the get command is a linux command (I think). Do I need to be running linux to sign up?
I am brand new to Raspberry Pi and would like to use one to automate a Christmas light show. I don’t yet know the things I should ask about how to get started toward my goal. I guess I need some pre-basic instruction on where to start.
Thank you for taking the time to read my post!
Larry Crouse
I’m guessing that all this gibberish means it didn’t generate an SSH key? Because I didn’t get the result the instruction said I should. So… what did I do wrong?
Is there a tutorial to learn linux programming? (need to ask more) I have almost no experience with linux so I need to start in the sub-basement (ground floor is to advanced for me)
@Lcrouse there is also a way to avoid all the SSH key and git stuff and just use the balena command line interface. To do this, follow these instructions https://github.com/balena-io/balena-cli#standalone-install and then one you can successfully run balena login you will be able to push code using balena push MY_APP_NAME
