Grabbing logs: error opening journald follow descriptor: "Too many open files"
At some point and without some apparent reason, the containers deployed on my devices stopped showing log after throwing the error in the subject.
How can I get around this?
Thanks in advance,
Federico
Can you try to run sysctl -w fs.inotify.max_user_instances=512 in the HostOS? If this fixes the problem we know what the problem is. You can validate that the command work by running sysctl fs.inotify.max_user_instances which should yield 512.
If this fixes the problem, could you grant us support access to such a device as well. We would like to research how many inotify instances your application uses to find a sane default value for BalenaOS. Thank you.
Also if this fixes your problem this (https://github.com/balena-os/meta-balena/issues/1592) would be the issue to track.
Thanks, that fixed the issue! Unfortunately, I don’t own the device so I cannot grant such access.
Thank you
I ran into the same issue, running sysctl -w fs.inotify.max_user_instances=512 fixes the issue once the container restarts the next time.
Same issue here, running sysctl -w fs.inotify.max_user_instances=512 does not fix the issue.
Note that I’m running ResinOS-In-Container:
for balenaos-in-container, you’ll probably need to run sysctl -w fs.inotify.max_user_instances=1024 in the underlying host running balenaOS
