@garethtdavies I upgraded another of ours to 2.46.1+rev3 (for a total of three now) and once one of them encounters the issue, I’ll send you the UUID and enable support access.
Hey folks, any news on this front?
Sorry, your mail did not get forwarded, so no. I have forwarded the UUID to @floion and he will be looking into it…
Hi. So can you do the following changes to a machine? Try to disable auto power save mode by doing this from your container:
echo “psmode=0” > /proc/mbt/hci0/config
and then
echo “pscmd=1” > /proc/mbt/hci0/config
Let us know if disabling auto powersaving changes anything
I did the changes on the machine you shared support for until you manage to do them from the container
Hi, it looks like that machine has been rebooted and the changes that I did were not meant to be persistent between reboots so now auto powersave mode is enabled again. So please do as I suggested above and let the machine run the code for longer so we can see if that made the issue go away.
@floion we’ll make some changes for that and get back to ya on whether or not it works. Thanks!
and then
@floion - I attempted to execute the commands above in my docker container via the docker RUN command.
RUN echo "psmode=0" > /proc/mbt/hci0/config
RUN echo “pscmd=1” > /proc/mbt/hci0/config
While testing on a local development Fin I noticed the second command setting pscmd=1 did not take. I tried it out myself while sshd into the container and confirmed. Any guidance? I can change psmode, but not pscmd.
Toggling psmode:
root@2179fe0:/app# more /proc/mbt/hci0/config
drvdbg=0x7
idle_timeout=0x3e8
psmode=1
pscmd=0
hsmode=0
hscmd=0
gpio_gap=0xffff
hscfgcmd=0
sdio_pull_cfg=0xffffffff
sdio_pull_ctrl=0
test_mode=0
root@2179fe0:/app# echo "psmode=0" > /proc/mbt/hci0/config
drvdbg=0x7
idle_timeout=0x3e8
psmode=0
pscmd=0
hsmode=0
hscmd=0
gpio_gap=0xffff
hscfgcmd=0
sdio_pull_ctrl=0
test_mode=0
Attempting to toggle pscmd:
root@2179fe0:/app# echo "pscmd=1" > /proc/mbt/hci0/config
drvdbg=0x7
idle_timeout=0x3e8
psmode=0
pscmd=0
hsmode=0
hscmd=0
gpio_gap=0xffff
hscfgcmd=0
sdio_pull_ctrl=0
test_mode=0
@scarson iirc that won’t toggle but nevertheless you need to export pscmd too in order to see psmode changed in /proc/mbt/hci0/status
And as an aside, you should not do these from RUN but rather from a startup script or executable you have in CMD
@floion thanks for the help- we’ll be deploying these changes across our fleet today and we’ll keep an eye on stuff to see how it goes. Stay tuned!
Hi. Did these changes help with the issue you were having?
Hi, circling back to this. Did the changes help?
