During my recent evaluation of balenaOS on the IPC, I encountered an issue that has raised concerns regarding its performance. Upon deploying the OS and initiating operations, I observed a significant degradation in system responsiveness and speed. This issue was particularly evident in the high virtual memory usage, as indicated by the output of the “top” command provided below:
Mem: 884052K used, 7092276K free, 10552K shrd, 53092K buff, 489932K cached
CPU: 0% usr 0% sys 0% nic 100% idle 0% io 0% irq 0% sirq
Load average: 0.00 0.00 0.00 1/186 8746
PID PPID USER STAT VSZ %VSZ %CPU COMMAND
8746 8741 root R 4144 0% 0% top
1755 1 root S 1531m 19% 0% /usr/bin/balenad --experimental --log-driver=journald --storage-driver=overlay2 -H fd://
2815 1 root S 1530m 19% 0% /usr/bin/balena-containerd-shim-runc-v2 -namespace moby -id ee566c4114afd11dd6d8f4565c85
1821 1755 root S 1459m 19% 0% balena-engine-containerd --config /var/run/balena-engine/containerd/containerd.toml --lo
2798 2730 root S 1314m 17% 0% balena start --attach balena_supervisor
2835 2815 root S 324m 4% 0% node /usr/src/app/dist/app.js
1656 1 root S 314m 4% 0% /usr/sbin/NetworkManager --no-daemon
1250 1 root S 307m 4% 0% /usr/sbin/ModemManager --log-journal
1 0 root S 156m 2% 0% {systemd} /sbin/init
2332 1 root S 77820 1% 0% /usr/sbin/chronyd -d
Could you please help me figure this out? Is this performance level correct? If not, I would like to understand the root cause of the issue.
