I’m trying to build a custom DNS server using Balena, and I think I got stuck at a point. I searched around for this issue but couldn’t come to a conclusion so I want to see what the community has experienced in this topic.
When I try to bind port 53 in my docker-compose.yml file, the service fails to start because dnsmasq is already running on the host. Is there a way to disable dnsmasq and what would the consequences be in that case? (when I bind it to a different port, it can listen but not respond via UDP, but I think that’s a different issue)
Another container that runs on the device is a web service and that starts and listens fine, I can query it and get a response as usual.
Hi, can you please share your docker-compose and Dockerfile a well as the version of balenaOS? The OS does have dnsmasq running on port 53, but it’s binding to 127.0.0.2, so it shouldn’t get in the way.
Sure I’m using balenaOS 2.38.0+rev1 for qemu machines and balenaOS 2.48.0+rev1 for raspberry pi, perhaps I shouldn’t use a network for this? I did it that way because the DNS container needs to talk to a Redis instance but that shouldn’t be exposed to the LAN.
EDIT:
In the meantime, I found an application issue and solved the no response thing, now only port 53 remains.
I realised that I didn’t set privileged: true on the service, so please see these updated files:
FROM balenalib/%%BALENA_ARCH%%-alpine-node:12.18.3-3.12-20200915 as buildbase
FROM balenalib/%%BALENA_ARCH%%-alpine-node:12.18.3-3.12-run-20200915 as runbase
FROM buildbase as depskeleton
WORKDIR /app
# Install NodeJS and build dependencies
RUN apk add --no-cache \
make gcc g++ linux-headers gnupg git zlib autoconf \
automake zlib zlib-dev python2 python3 libpng-dev
RUN yarn global add lerna
ENV LIBRARY_PATH=/lib:/usr/lib
COPY ./package.json ./yarn.lock ./lerna.json ./
COPY ./patches/* ./patches/
COPY ./packages/<corp_package>/package.json ./packages/<corp_package>/
COPY ./packages/dns/package.json ./packages/dns/
COPY ./packages/web/package.json ./packages/web/
## Production deps
FROM depskeleton as proddeps
ENV PYTHON=/usr/bin/python2
ENV NODE_ENV=production
RUN lerna bootstrap
## Development deps
FROM proddeps as devdeps
ENV NODE_ENV=development
RUN lerna bootstrap
## Source code
FROM devdeps as sources
# Tell the builder to build an optimised version of the bundle
ENV PATH="${PATH}:./node_modules/.bin" \
# Set the max memory higher, it's 1.5G by default. This option specifies how
# much memory the program can use BEFORE garbage collection. This should be
# less than the available system memory.
NODE_OPTIONS=--max_old_space_size=2048
# Copy the whole source code into the container
COPY . .
## Build
FROM sources as build
ARG PACKAGE
WORKDIR /app
RUN yarn lerna run build \
--scope=@<corp_org>/${PACKAGE} \
--stream \
--include-filtered-dependencies \
--concurrency=1
## Runtime
FROM runbase as runtime
ARG PACKAGE
ARG EXPOSE
WORKDIR /app
COPY --from=proddeps /app .
COPY --from=build /app/packages/${PACKAGE}/build .
EXPOSE ${EXPOSE}
ENTRYPOINT [ "node", "/app/index.js" ]
