Hi @knaps
Unfortunately not. This is something we are currently debating internally.
The list of subdomains can and do occasionally change (and are also dynamic, for example the use of UUIDs as part of the domain), so if you’re not able to handle wildcarded domains then I believe the only guaranteed solution at the moment is that of a proxy server.
Best regards,
Heds
